expedition film trucks
expo80
thanks for the complements guys!
well i have about 98% of this engine finished just waiting on a couple gaskets to come in
here is a pic of the part matched intakes and the upper intake and water inlet installed
expo80
new harness, and oh i forgot to mention a supercharger:ylsmoke:
expo80
Ran into a little bit of an issue with the super charger,
I always dry fit any machine piece before i assemble it to makes sure that the two surfaces meet flush, anyhow when i went to install the tbody flange to the super charger i noticed that there was an Allen head bolt that protruded into the body of the compressor part of the supercharger. I pulled the tbody flange off and noticed that they clearance the compressor body for the bolt but not enough or they did but somewhere down the line thy sourced different bolts. so my fix for this was to clearance the bolt, took a few mm off of it an all was good
expo80
harness extended, vacuum lines hooked up, intake hook up, break booster line installed...super charger 98% done just waiting on a coolant housing gasket
expo80
