classic range rover diesel conversion
ArmyRover
I think so and a bit more affordable to drive!
Not as cool as your 300tdi Disco though.
REDROVER
Do you have any recent updates on the conversion?
the update is. motor / trans is back in, i am waiting for the drive shafts to arive, and rover is ready for adventure again.
i have been using my H1 for travel last few months, but its time to get back to my rover i even moved the tent from the rover to H1, but this week everything is going back into its place
I MISS MY ROVER,.
REDROVER
here are few pics of the short shaft made to adapt t56 to work under 4x4 t case,
94Discovery
I was doing the math for the final ratio it is between 1500 1600 rpm if it have the .50 6th gear .
I am also waiting to see when driving 100km what the fuel economy will be and how it handles .
REDROVER
i actually don't use the first gear to take off, it has power to take off on second, by tomorrow i will get my RPM gauge and i will see what rpm i am running, and i will have the interior work started ,
REDROVER
very close sir, 75 mph at 1720 rpm , :)
( VS BEFORE AT 2600 RPM )
i LOVEEEEEEEEE THE WAY IT DRIVES NOW, exelent gas milage 50% less noise and heat ,
6th gear is almost not needed unless i go over 70, shifts very smooth . and water temp is at minimum .
ERIC
oskarf150
