What did you do to your Expo Jeep today?
steventexas
I'm going to re mount and modify tent/rack relationship to be lower and more tucked in. I moved this RTT back and forth to test wind deflection and found the biggest drag is created when i leave a gap between the front deflector and leading edge of the RTT. Once I closed that gap the soft top barely makes a sound and I have ran at hwy speeds against west Texas 30mph gusts. I heard a guy say he turned his around to more resemble an aircraft wing and create lift. Hmmmm. i think I'll try that too.
When complete, the rack that mounts the tent will be removable by two people so it can be left with fridge and kitchen at a base camp so the LJ can go do the deed.
What I find though is I keep moving rather than setting up a big camp. The quick pop up with bed clothes already there and a fridge that I can access from he back door is handy.
There is specific storage under the tent, built into the rack, Ie: ladder hanger and a flat wide "pouch" that will handle lite, hard to wad up bulky things like soft top accessories
Clearly this reply belongs in a different forum so I may look for that but when I do the rack mods next week on my expedition Jeep I will post the update.
I believe fewer appendages and wheels are better but there is also limits on stacking your rig.
I have to remind myself that less is better and the reason we seek the road less traveled is freedom from hassle.
I hope the experiments on this are helpful to others. I'm glad to share.
nevadajh
REAR FLOOD LIGHT
Today I installed a rear LED flood light. Bought it off Ebay for $30 and its built well and really bright.
GP'd
Played around in solidworks a bit planning my Dana 30 Truss. Given that I need to pull the axle and install Currie LCA Mounts after tearing one and cracking the other, I might as well beef it up while it is out.
The truss will be underneath the tubes on both sides. (the other side was hidden while I saved this image)
Build
dirty Bakers
Conservative
Flushed the cooling system in preparation for summer. Looked at eleminating the ashtray (or using the out cover) to accomidate another power outlet and aux. Switches.
hansonian
I installed a B&M transmission cooler and a temp gauge to monitor it. I'd been having some issues with it getting too hot and slipping into limp mode. Hopefully this cures it.
warrpath4x4
ordered new tie rod ends yesterday, suppose to be in today. if its not snowing tonight ill get them put in and maybe my new u-joints so i can go exploring saturday or sunday
toymaster
I see why you sold me your ploy basket. Cool roof rack system.
The last thing I did to my jeep before I left was change the oil after the 5K mile trip, install Currie swaybar links (the RE ones were worn out), and wrap my steering wheel in 550 paracord. I drove it back from Yuma with the paracord on and it is no where near as abrasive as I had feared, even smooth. The only difference was a slightly larger wheel but that was gotten used to fast. 'tis a handy place to store a lot of cord.
While I'm off working I ordered a cool side mirror from Axia Alloy which attaches to the rollbar for when the doors are off, a fridge, RTT, and last but not least I'm trying to get Kurt to supply me a on-board shower set-up.
beardus supremous
Toymaster I am diggin' the paracord wheel wrap. I had a bunch sitting around so I made Paracord braded grab handes with some last year. The stuff is really handy.
PNWINFERNOPRO
@PNWINFERNOPRO
Thanks. Hope you are enjoying the Poly basket.
Paracord wrap is sweet.
