Hearing that about your width makes me feel a little better. I thought it was just me with a tight fit. The 1.5" looks like a good size tube.
Jimmeh, are you thinking of Chelsea or Muncie pto drives?
have you thought of using a dimple die on those holes for a bit more traction? slidersteps look good!
The whole truck looks absolutely awesome! I may have to look into a buckstop for my front bumper after checking your truck out. Also kicking myself for getting OEM flares instead of bushwackers, but may change that in the future. I also really like those sliders! You went ahead with the bolt on design for those?
At work, we have remotes for our trucks to bump up the idle for when we are pumping off product rather than going back to the cab to do it each time (at least on our "newer" propane trucks. Our propane trucks all have the allison transmission, though they have a PTO for running the pumps). Have you thought of getting some sort of setup to where you don't have to go to the cab each time to bump up the idle? If you're interested, I can figure out the manufacturer of the remotes. I actually know it, but the name has slipped my mind for some reason. I'm sure they could work with you on designing something.
We made it to camp and once we had everything set up and had dinner, we took a walk and saw a hornytoad lizard, we saw him three times total, so we christened the spot as Camp Hornytoad.
We met up with the rest of the crew on Saturday morning and headed down to the remains of Murietta and started our way up the canyon toward our goal. We worked our way up and came to a "Guzzler" and the only one of our group that had ever been there, was on an atv some years ago and he was just following, so it took us a while to figure out the trail. From the guzzler, we started up what is labeled as a Jeep Road. Pretty much the only thing using the road any more are ATV's. On the shelf.
And then we finally found a spot too small/rough for a stock truck. We had turned up the canyon to continue our (new trail from this point on) journey.
There was a small ledge that was too tall for the approach angle, open diff, belly dragger Chevy, so I attempted the bypass. Unfortunately, it was all depocomposing granite, so imagine a course sand. I buried the truck and made it to within a few millimeters of taking the bed out on the rocks.
After a lot of winching, jacking, rock stacking, help, snatch blocking, etc, we got the chevy out of it's hole.
Here is the ledge.
The only damage and that was from a rock being thrown into place. A big thanks to the Battle Born Cruisers of Northern Nevada for the rescue.
They needed some metal to keep you from stepping through them and to make them more effective as a step.
Oh and I decided to add some seam sealer on the underside of the tubes/metal
Both sealed and drying
Test fit and measuring for the "legs"
I decided to use Durabak spray can bed liner on them so that there was some grip and hopefully it will hold up to road spray.
The final product
The are the perfect height and distance sticking out for use as a step, but not so much that they are in the way when getting out.
Jack
Some great pictures showing the terrain and obstacles faced, LOVE IT!! Really like you are not afraid to put the truck in some tough spots. :bowdown:
How have these been holding up for you? Look great and the concept is very useful.
Also, how is the engine driven air working, I have done the Kilby kit on a couple Duramax's in the past, one is installed on a close friend, camping buddy's LBZ and we also had belt issues. He has spares and after the first alignment issues we had all has been good for him and man does that set up put some air out.
Anyways, nice to see your complete build over on this forum, been surfing it for alittle less than a year now but finally started a user name a couple months back to see more and after seeing you on DP.com I figured I look over here for you because it sounded like you where legit and not another regular guy on DP talking off road lol (no disrespect to DP members at all) just easy to see you are truly putting your HD through some tough trails for a truck this size..... KUDOS!!! Love it and sub'd to follow more.
Nick
Thanks for the compliments. I have gotten some looks when someone sees it on a trail. I have to say, it has impressed me with where it will go and where it will fit. I know I talked to you about a year ago regarding a Cognito 4" NTBD lift, I just decided to try it as is and see how I like it. The plus is that I still fit in the garage with the camper on, which I wouldn't with a lift. So for now, it stays.
The sliders have been holding up great because they have only had to be steps so far... They make getting in and out easier and they don't stick out too far when getting out so that they are in the way.
The OBA has been great, almost. Because of some manufacturing issues, the a/c compressor and york compressor don't exactly line up, so I have positioned the idler pully to split the difference. As you can imagine there is a belt chirp that is driving me insane. I have been through three idler pullys and two belts trying to figure out what the problem is. I love the system otherwise, but this chirping has got to go. If you have any ideas for getting everything aligned better, I'm all ears. Without re-doing the bracket holes to move the york, I am at a loss.
My goal this weekend is to tackle it one more time. I even ordered another york clutch assembly and am ready to address the a/c clutch bearing, buy a different belt (two kilby versions so far) and attempt to source another idler pully, hopefully from some OEM application versus the kilby supplied one. Like you said, amazing amount of air. I had one on my LC and have friends with yorks and sandens on their rigs and once you have a belt driven OBA, you can't do without.
I haven't updated the build with the AeroTanks 52 gallon fuel tank yet, which is one of the better mods. I love having capacity.
Hopefully, now you understand why I am interested in 2.5" shocks and where I am coming from.
Thanks again,
Jack
