cowboy 4x4 ford van
cowboy4x4
Trial fit
cowboy4x4
I'm going to put some sort of bracing to the frame, there are five bolts going through the pinch seam, I think what I'll do is have two brackets at the back and two at the front and nothing in the middle. That should have enough distance to allow any body/frame movement.
bknudtsen
I would have to go look at my van to be sure (sorry, coffee time right now), but is there a way to run the bracing to the body mounts like many of the Jeep rocker guards do? That would help marry them to the frame/body, but still allow some flex. I see Oz's concern about having the slider mounted to frame and body at the same time. Might tear the pinch seam over time.
Brad
cowboy4x4
On my Truck I had the mirrors whited out, so i figured I would do the same to the van, trying to get away from the "white work van" look.
Henrybrowne
