1995 Montero SR Build
I just picked up the cylinder heads from the machine shop. A respectable $177 and they did a great job. Cleaned, pump tested, replaced valve seals, surfaced, and lapped two valves.
And the mounting surface of the block. This surface looked like the one in the background. (EDIT: I cleaned the block surfaces, not machine shop)
ElRob
I'm ready to see this on the trail. I haven't seen her in action since I've joined the overland community.
1911
Looks real purdy Scott. We can thank the Japanese for making four-valve-per-cylinder motors reliable and cheap. A very efficient head design.
In due time. Summer is upon us.... and its gonna be hot!
Thanks Lee. Can we thank them for that? So far so good. But by golly, we needed three Japanese 9 year old girls remove the motor from the truck....
Beautiful
She sure is!
Some of today's progress
Chasing (re tapping/cleaning) the threads of the head bolt holes.
New head gasket
Installing the cams
And how I left it tonight....
I never sent the injectors in to be cleaned.... and I'm starting to run out of cash. So I'm taking a chance here and after lots of internet research, I'm going to attempt cleaning the injectors myself. I won't have any fancy flow ratings, but will have clean injectors none the less. Injectors are basically solenoids that open an close passing pressurized gas through a tiny valve. So I'm going to mimic the action by opening the solenoid manually, while allowing a pressurized solvent to flow through.
I've already cleaned my injectors in a ultrasonic cleaner filled with degreaser, shined them up nicely.
Here's the actuator rig I just finished building.
I still need to research the voltage that goes to the injector so that I don't burn it up. But basically, the plan is to connect to a small motorcycle battery and actuate the injector via tapping a momentary switch. I'll have another rig setup to flow the solvent and air. So far, my plan is to use about 12" of fuel line filled with carb cleaner (or denatured alcohol) then press the air nozzle into the hose applying the necessary PSI (yet to be determined), expelling any junk inside.
.... Actually........... I didn't think of that...
But, its a $4000 rig and I don't want to bring it home and dont want to clean injectors at work...
