Box Rocket
The rubicon is not the way to do it FWIW , as you need to cover the whole visible front as far as the slightly over top of wing,(fender) or hood curvature , its done mainly to combat low sun angle reflection , it is of limited use re roof lights , so these need to be mounted far enough back so as to place the hood in shadow , if you want to use for bush driving at night, which is usually a big no no anyhow if at all avoidable . Not trying to preach , just from experience .
Little too much "my way or the highway" in that response IMO. The Rubicon hood decal while it may not be "perfect" it will be better than nothing for sure. It will still eliminate a fair amount of glare and be benificial for the driver.
How on earth is using roof light for bush driving at night a big no-no? Isn't the point of having aux lights to be able to use them at night?
