Overland Journal Project Land Rover Discovery 4 (LR4)
SteveMfr
Supporting Sponsor
It can go higher with a combination of the two.
The EAS ECU has a plausibility range of ~100mm meaning that the total possible range of adjustment is roughly 100mm (between 3"-4") on the LR3/4. Exactly how much you can go up or down depends on the position of the original EAS calibration within this range. If the vehicle was calibrated low in the range, you can't lower very much but you have more room to raise the suspension. If the EAS was calibrated high it is obviously the inverse.
Discounting all other factors such as drive train components, suspension geometry, etc, the problem with lifting an LR3/4 that much on an otherwise stock suspension is that you simply run out of adequate suspension travel. You may have a bit more clearance under the vehicle, but you'll be playing teeter-totter over small obstacles due to a lack of droop.
lwg
Can the tool monitor Transmission temperatures or T-case temps? I recently started towing an RV with my LR3 and would love to know these values.
lwg
Most excellent. Last question. If I purchased one for my current LR3 and eventually upgraded to an LR4 would the tool transfer to the new LR4 or would I need to purchase a new tool? Guessing the hardware is the same, just a software flash and some $$ and it could be done.
Kudos on getting this project going!
SteveMfr
Supporting Sponsor
Exactly. SW transfer is a non-issue. You would have to purchase a ne VIN license for not tooooo much. Britpart dealers are free to make their own prices and we are asked not to quote any - but somewhere slightly north of GBP50... (shhh :p )
Thanks on the kudos!
chirigringo
Besides AB, anyone know who is offering the iidtool in the states? I can't seem to find anyone else. Any suggestions for UK dealers who might ship to the states?
jordanP13
