How to weld with dual batteries, jumper cables and a welding rod- video
CTMike
I made this video on how to weld using dual batteries, jumper cables and a welding rod. Hopefully this will come in handy for trail repairs!
ZG
Busy Fly Fishing
Great video, thanks for posting! Do you mind if I share this on the RN Facebook page?
CTMike
Please feel free to share it. This is a great skill to have, so many problems can be solved with welding
uk trailer guy
Great video. Nice and informative. Was pleased to see you happy to put your money where your mouth is and test your theory! Well done and thanks again :)
JKMikey
Saw a guy do this on the trail once. Had to scab together something (can't remember now what it was) on his front axle/steering. We used random bolts/scrap metal we could find in our trucks. He managed to get off the trail and onto his trailer.
Definitely a cool site to see.
Antichrist
Useful video.
A couple of things worth pointing out.
Make sure you're upwind of the batteries when welding if you're doing it with flooded cell batteries.
Rod choice; 6010 rod is a good choice for carrying in your rig. A low hydrogen rod, like EXX18, have a fragile flux coating, must be kept really dry (they readily absorb atmospheric moisture) and give poor results if the joint isn't really clean. 6013 would be good in cases were you want to change the polarity so you get less penetration for welding thinner material.
Antichrist
Would this work on aluminum, too? What rod would you use?
For stick welding Al E4043, reverse polarity (electrode positive).
If you're thinking a Land Rover body panel E3003 might work better, but using batteries would probably be too hot for something that thin.
iStan814
