Post your Mitsubishi Pajero Pics
nwoods
Definitely look good, the 10.50 width is certainly the size to go with.
I agree. Check out Billygoats sporting 33x10.5x15 BFG KM2's. Looks like the perfect size to me.
DESTRO
Mountain Warrior
thanks.. so much more tire than the stock 265/75/15's i replaced.. 3.5 engine still has more than enough power to turn em but, i can feel the extra weight.. not as noisy or as rough a ride as i expected but, the low pitched rumble at low speeds and the higher pitched "mechanical sounding" whine at hwy speeds definately leaves no doubt that i'm driving on agressively treaded mud tires.. that said, i like em.. i think they look good on the truck, add about 2" of ground clearance, and my sound system biatch slaps all road noise with extreme prejudice.. i'm looking forward to taking them off road.
DESTRO
Mountain Warrior
had a little fun on a construction site.. put the new SS M-16s to the mud test.. outstanding.. even the traction has traction.. never stopped moving forward even with a little wheel spin in 1' 1/2 ft deep, thick, partially dried, and soupy mud. i didn't time the exact moment it kicked in from the time my wheels began to spin a bit but, the A/T hold worked as it should to reduce wheel spin when solid traction is more of a challenge..
Found some pretty well used 33x10.50s on 15x8" wheels.... Will run them on the truck for a bit. I like the looks of the wheel and will put the duratracs on these wheels.
LOL, mine needs so much body work, it would be FAR cheaper to buy a new one and start over.
That's BS, Nathan, just takes a bit of sweat and a few bucks in paint to get it done. I changed the color of mine for ~$200 all in. Prepped and painted like a pro might but was only concerned about the color change... its a trail truck, remember?
KarmannMarco
Those look great! What kind of wheels are those? After buying brand new 31x10.5 ( which are night and day compared to old stock tires ) i really wish I would have picked the 33x10.5 instead.
DESTRO
Mountain Warrior
A steaming pile of It Nathan.. Lol I plasti-dipped mine with rattle cans for under $100.. it turned out better than it needed to satisfyIMAG2894-1.jpg
sunnyaz
