Old Rovers Too Feeble?
tacr2man
Seeing as the subject of outback Australia has been mentioned , a little story , that shows remote travel is possible with the right outlook .
I was taking a vehicle into a remote part of W.A. (just to give an idea of size its 3.6 bigger than Texas) racing a possible road closure due to a cyclone coming towards land. I was towing it with my 110CSW . i had been driving about 7 hours without seeing another vehicle on a dirt road. Arrived at a creek crossing to find a Chrysler valiant 4 litre sedan sat in the creek at the bottom of the bank . So I ask the guy(aboriginal) will he be long , as he had the hood up. He says that was just drying engine ignition system , Went in a bit too fast then ?
I said , Yeah the brakes dont work too well he replies. Asks me to give him a push , which i decline as i dont want to get soaked , no he says with my 4wd . Told him would not be good for back of his car , which doesnt seem to bother him , so I drive down and push the back of the car with my bull bar , and across the creek and up the other side. When we are on level ground theother side i pull up alongside and use my onboard air to blow out his dizzy, etc . The back doors open and a load of water runs out , sat in the back are two elderly aboriginal women. Whilst under the hood i noticed that the front windscreen is held in with silicone bath sealant, and doesnt reach as far as the passenger side pillar by about 4 or 5 inches , he starts the engine , and they roar off into the distance . We come across them about 45 mins later stopped again , he says run out of gas We give them a couple of gallons that the guy I am towing has in a can , its tipped into the tank thru a hole that was where the filler pipe goes thru the floor of the trunk and they are on their way again . Less than hour later catch them again , used all the gas up. They have made a campfire and just sitting by the car , i stop and they say when we get to the settlemant about two hours ahead give them a message so that his brother will come out and get them . Which we did . Most Australian (and others) only venture out there with multithousand dollar 4x4 s , and I still had to go and get them on occasions :safari-rig::(
Dendy Jarrett
Expedition Portal Admin
Staff member
My dad owned about a simple a vehicle as one can ever own ... a 1959 Volkswagen.
And still it had to be pushed off to start on cold mornings.
I suppose any vehicle of age could prove problematic and new trucks as well.
Then it comes down to the question: Do you want to be broke down in comfort or broke down in an old truck :)
Personally, I have owned a series IIA, D-90, D110, DI Disco, DII Disco, Range Rover Classic (x's several), P38 RR, and a few MK3's. Now driving my second LR3. Of all of them ... the two most enjoyable and capable were the 1993 RRC (non air suspension from the factory) and now this well built LR3. The only drawback to the RRC was that I am 6 feet tall and my hair rubbed on the headliner. Not the case with the LR3.
And then there is this: Were are you gonna drive in the US where you aren't a day away from any parts or service you could need?
d
brushogger
I too have owned many different four wheel drives since the seventies. FJ-40, Scout, Bronco, Jeeps etc. They all had their charms and warts. My current one is a FJ Cruiser. It does it all and is reliable as a hound. It also gets 19-20 mpg. It is the best one I've had. It's like comparing and MG midget to a Miata. Sure the MG is fun and can be kept running in some sort with a paper clip and electrical tape, but the Miata smokes it. My Fj Cruiser is actually as capable as my 40 was. After a 10 hour drive in the 40 you are pretty beat. In the Cruiser, it's still party time! The only disadvantage I see to the new vehicles is if they get flooded in a water crossing. The 40 or the jeeps just required a change of fluids and a drying of the dizzy. In a modern vehicle, it can possibly be a total loss due to wet electronics and corrosion of connections.
alaskantinbender
Here is another old feeble rover. I just gave her some new 34 inch skinny TSL's. Still cruises along at 60MPH on the interstate.
Not bad for a 50 year old truck....:bike_rider:
LR Max
Local Oaf
Reminds me of my 109 when I've got my 34" TSLs mounted (instead of my 235/85/16s). Makes the truck look pretty good!
zhukoveli
