How wide can you go?
Capo
Happy Camper
I can understand reaching and running with the square rig bit can't quite get my mind around sailing into the wind; unless the COE is forward of the CLR. Then I can imagine it. Would have notable weather helm then, but a little bit is manageable. How high can it point? Steer with an oar ( on weather or lee)? The transportability of a container boat would be awesome and open up a whole new world. The bow and stern sprits (not sure of the proper term) would have to fit in a high cube - just under 9'.
Your boat got my vote ( I voted). Hands down the coolest. The others were very nice traditional builds, but the Viking is very intriguing. I'd say that victory is highly likely. Let us know how it goes.
They use a white oak I assume. What is the source?
Where is Hokkaido?
Sorry for so many questions. I love wooden boats; bought the full size patterns for the "Spray" when I was 25 - some day.
Seeing that this is a G forum, one more question. How do you like the G400? I don't think they were sold in the US. Reliable? Powerful? V8 diesel sounds awesome!
Thank you so much for your vote!!
A Viking ship doesn't point high but high enough to sail into the wind. This and the Vikings' navigation skills are what made them such successful intercontinental mariners. The square sail must be fully angled and trimmed flat on the wind cutting edge of the sail. The enclosed picture shows the special sheet which creates the sharp edge for pointing high. This is partly why the stem is high on a Viking ship.
The oar is always to starboard. In fact, this as many mariner terms comes from Norse. "Styrbord" : styr = to steer, bord = side of a ship (or an individual plank of the hull) ie the steering side of the ship. As on all boats, the better the breeze the better the speed and the higher you can sustainably steer. If you can find protected flatter water behind low islands and land points you can point even higher.
The oak is prime German oak, luckily of exceptional quality. It is the remaining timber from the building of the world's largest Viking Dragon, the Harald Fairhair. The trees were bought on root, ie the ship builders personally went to Germany, selected their trees, cleared the roots and felled the trees with a major part of the roots intact. This is very hard work but it's the only way if the timber is for a ship. The root is the strongest part of the tree and it is naturally curved which makes it perfect to use for the frames.
Hokkaido is Japan's largest Northern island, the capitol city is Sapporo. It is a cool place with mountains, ski resorts, hot springs with geishas and it isn't as heavily populated as the main island.
The G400 is to me a great diesel G. It was conceived during the time when MB had problems with their electronics and the 400 got a fair share of those problems. It took me a couple of years of replacing electronic modules to make it function fine. Although I must say, with all the problems it caused me, never did it leave me stranded. It always made it to the workshop on its own steam. Most of the problems had nothing to do with the drive line. Mechanically it is solid. The engine is a torque beast and it sounds great yet inside it is very silent. In delicate terrain you need to drive it in manual mode to make sure it doesn't downshift and throw too much torque on the wheels. I have installed a chip with three driving programs for the gear box. This helps and makes it possible to use auto-mode more often in slippery terrain and it is great when pulling heavy trailers on hilly motorways. I also have a high quality engine chip which reduces fuel consumption and boosts torque throughout the whole rev range, peaking at 620Nm. There is way over 500Nm already from 1400rpm. Hp is 300. The only mechanical issue you must be aware of is the torque converter. The engine is so powerful people don't bother to use the low gears. This causes of course tremendous stress on the converter and the rest of the gear box and the 400 has gained a bad reputation from such abuse. If you always use the low gears off road, put high quality oil in the gearbox and keep the transmission oil cooler clean from mud, then you will be ok. I've done 120.000 km without a problem.
Like all luxury Gs it is on the heavy side.
Capo
Happy Camper
Major 120.000km Service G400
Cam chain and chain tensioner changed, cam lobes looking perfect. All the stuff that needed to be removed to get visual access around the engine bay has amounted to a huge pile beside the car. A good all around visual inspection is crucial for being in control of what's going on with all bits and pieces on and around the engine. A few minor hoses and connections have been replaced out of precaution.
Capo
Happy Camper
Cleaning of the recirculation ducts is clearly needed after 120.000km. It will likely cause malfunction of the ERC unit if not cleaned.
Capo
Happy Camper
The transmission oil cooler must be kept free from mud or you may cause unnecessary wear on the torque converter.
Capo
Happy Camper
There are four radiators in the front. The three visible ones in the picture are for water, engine oil and aircon. The transmission oil cooler is located right behind.
Capo
Happy Camper
The brake rotors and pads need replacement. A heavy vehicle driven in sand, mud and snow will consume brakes. My braided brake lines are not homologated for Switzerland, (strangely!) so they will be replaced by original extended lines. According to my mechanic, this will bring back the braking performance. The removal of +300kg will also help.
Capo
Happy Camper
Only one of the heavy duty shocks has a leakage after approximately 40.000km. An overhaul should fix it. The vehicle's loss of weight will be much appreciated by shocks and brakes.
Capo
Happy Camper
A tiny oil leakage has been traced to the port side turbocharger and will be sorted. I hate oil spill on and around the engine.
Capo
Happy Camper
The base mounts of the bull bar are kept in place to facilitate quick mounting/dismounting.
Capo
Happy Camper
A general cleaning and touching up underneath the vehicle and around the engine will finish the job. All protective plates and the plentiful heat shields will be removed first. As you can see in the picture I have two trailer light sockets. The one to the right is a new one I had installed which bypasses the useless and expensive control unit of the trailer lights which has broken down twice.
Capo
Happy Camper
Both the G400 and the G55 suffer from a broken rear window mechanism. Very common on the rear windows whereas the front window mechanisms are ok. Here's a pic of the makeshift repair of the G55.
McBride
Is duct tape as popular in Europe as it is in the US? We use a lot of bailing wire too. Essentials. Sikaflex sealants and tape are pretty awesome too; great longevity when used correctly.
