Jakes1994 FZJ80 (BIG ORANGE)
60Dan
Awesome pics dude! Great to hear everything worked out as planned!
I knew you would dig a Landcruiser!
ab1985
We had a great time. It was fun hanging of again and we enjoyed meeting everyone's family (my daughter is still talking about the trip).
Warlord6
HMFIC
What rear shocks are you running? And what LED's are those? Thanks. Great build btw
I'm running OME Long Travel resi's front and rear. The LED bars are Lifetime LED with Cree LED's, and the rock lights are VisionX tantrum Ultra whites.
Sempertoy
do you have any more shots with the rock lights? Id like to see where and how you mounted them. Did you wire them straight to a switch or did you use a relay in line? Thanks!
Jon
Warlord6
HMFIC
Jon
The lights come with a control module and a relay. The control module is wired directly to my fuse block. Each light has a plug that goes into the relay box which is wired to the control module. There is no switch. The lights operate off a remote or by the buttons on the control module.
I mounted the lights using a heavy duty epoxy. They come with 3M adhesive pads, but they don't stick very well on the frame.
Rear bumper
Rear lower link
Behind front tire
Front bumper
Sempertoy
I ordered my kit and it should be here today. Does the kit include everything needed for the job, or did you have to use outside parts. If so, what did you need that wasn't included?
Warlord6
HMFIC
It includes everything except some simple connectors to wire the power and ground to the source. The power cord it comes with has a 12volt cig adapter. I cut it and wired it directly.
Henrybrowne
