AmbuLand build thread
Abitibi
Sorry, I meant any benefits to heat the diesel? Heat for veggie is a must (I'll be running two tanks)...
Sent from my iPorn using TapaChat HD
Abitibi
Yes, moving along! We had good weather, the days are getting longer and I kinda got to escape from kids and wife :)
Before carrying on with the Espar/water system I had to work some more on the veggie conversion. Both systems are somewhat linked together so made sense to figure exactly where everything would mount...
First thing, get that frame all cleaned up and painted with Por-15. Same for the veggie skid plate. Might as well get started with mounting the valves, filters and some fuel/coolant lines...
Doesn't seem like much but took quite a while to get it all installed. Most of it is done. Just need to tap into the coolant lines and build an aluminum veggie fuel tank. If anyone is interested in the WVO details let me know and I can go more in depth.
I kinda got distracted along the way... Since I already had the Por-15 cracked open, I figured I should share the love ;)
Next in line, coolant plumbing...
Cheers
Mr. D
Sent from my iPorn using Tapachat HD
djbonsu
Good progress! Any more details on the WVO? Looking to do this but im a pure novice at the whole conversion setup.
tgreening
I didn't know por-15 could be used as a finish product.
I'd love any and all details on the espar and wvo systems
It depends on your expectations. If you use standard POR-15 as a finish coat, and it will be exposed to direct sunlight, it will lose it's blackness and take on a purple-ish tint. In this scenario you have to put down your por-15 and then use por-15 topcoat. I believe you can use regular paint as well but it's been awhile since I've dealt with the product. I know there are some gotchas to using a topcoat. You have procedures to follow and a limited time frame to get it on before the por-15 base coat dries too much. It's all on their website.
Abitibi
I've read the same where it doesn't do great with UV so no concerns for the Ambo. As for my Patrol I simply add layers of spray paint as needed ;)
For the Espar I'll continue to details as I go along.
VanIsle_Greg
POR 15 in direct sun goes from gloss to flat in about 7 months. It is an amazing paint product, but it is NOT a topcoat. They do sell a UV clear for it, I simply sand it and use other stuff on top.
Looking great man, nice work!
VanIsle_Greg
So I have to wait 7 months before it finally turns flat?!? Not sure I can wait that long!
Pretty much...lol. The stuff under my trailer is still glossy and shiny after 2 years. The stuff on my swing out tire carrier in direct sun is flat after maybe 6 months. Still in great shape, just no gloss retention. The semi gloss paint I used on my brush bar over 4 years has maybe dropped 25% sheen in that time.
Great paint however, love the POR15!
cjken
The guy who bought my green quigley van was a Por-15 distributor on Martha's Vineyard
He threw in a few cans as part of the deal.
Just don't get it on your hands!!!
I learned the hard way!!!
xander69
