Zomblance build up
polksfinest
Well it been a busy week I have been working at a feverish pace trying to get this thing done by June 1st still up in the air if it will be done by then but must keep moving I spent last week going threw the build in my head and ordering all the stuff I would need like wheels and tires a/c compressor shocks springs and a bunch of little stuff. I rebuilt my Transmission right before I started this project so I just resealed it and added a deep pan and shift kit removed the parking brake housing and stuck it back in
Went and picked me up a set of axles from a 99 f350 I was told that the front was a Dana 60 before I made the drive but boy was I surprised when I got there but they had 4.10 gears. I guess they will have to do for now so I loaded them up and off to the house to strip them down
Found this little gem when I pulled the rear diff cover looks like a rebuild is in order
So I ordered gears and a limited slip for the rear and a ratchet locker for the front I was not going to do this at home so I took them to the shop
Well after getting the new 4.88 gears and lockers put in I started on the back axle think that it would be the quickest again I was wrong I swear people don't think when they build stuff
You can't get the dam springs out with the body on ******. Adapt and over come they say so I cut the spring hangers off to install my new 8 inch skyjack springs
Threw on some roll arounds to take a few pics and moved on to the front
cjken
Mine has that same spring access problem. I was going to deal with the springs before mounting the box, but ran out of time.
I was thinking of just drilling/cutting into the spare tire compartment to get at the springs when the time comes.
I can't believe the pace of your project!!! Amazing!!
polksfinest
Flight cancled it is a srw and I am going to run spacers
Cjken I was not about to cut holes in to the boxes after I spent a week water proofing them
Rounding out this week I got the front end and wheels and tires are here so I was really moving trying to get the front finished
Here you can see the colors I would like to use
polksfinest
Not really running on E got a lot a pissed off customers but they will get over it I have been shutting down the shop half days this last week to try to get it done here is what I am shooting for on the paint
The black strip is still in the air I want to make all the chrome black for sure
flightcancled
Sweet! Color combo looks good.
Instead of cutting holes into the compartment to remove the hangers couldn't you push the bolt out from the inside and just keep cutting it off in sections?
Slicky72
Agreed I like the paint scheme as well. Is that a punch list hanging on the door? If so looks like you still have a few items left :)
polksfinest
Yes it is there are still two more pages that are not hanging up
You could cut the bolts but how would you get them back in
I had a ton of boxes show up yesterday so today I stayed on it all day my plan for the weekend is to get all the motor work done and Trans installed tanks built and installed and start the a/c for the rear I took a different approach to the rear ac then most and went all 12 volt and water condenser instead of a air condenser here is a pic of the compressor 10,000 btu 27 amps full load add that to the 25 amps that the blower pulls and I am just over 50 amps I was trying to stay under 50 but I could not bring myself to spend 250 on a new blower motor that was a permanent magnet motor but if I did it would not need a blower motor resistor and would be a adjustable via rheostat
polksfinest
I did a combination of copper lines and rubber the only lines that are copper are the supply and return to the evaporator they solder those two lines together in ice machines that's what makes them so effective
Here's a shot of the water condenser coil and tank that will also per warm the water before it goes to the water heater
Still got some welding to do to the tanks more pics of them tomorrow
polksfinest
Ok managed to check 9 things off of my punch list got the new water pump, front cover resealed, rear main seal, injectors, glow plugs I also ran my new 1/2 fuel line up to the motor where it meets a bypass regulator fuel pump ,a/c lines and a new steering box ( ok rebuilt) plan for tomorrow is shocks, brakes and finish the fuel and water tanks
zhukoveli
