Eurosonic's Montero 2.5Gen Build Thread
eurosonic
I'm disappointed that ARB doesn't include recovery shackle mounts on their ARB bumpers.
So I welded some mounts that I made out of 1/2inch plate.
Cleaned them up a little
and sprayed them with paint
Should've done this long time ago
Toasty
I installed the AWD sport front axle assembly as well, such an awesome upgrade. No more vacuum nonsense, it just works.
Good work!
eurosonic
What's the issue with the factory Gen 2.5 front assembly? I'm not familiar...?
If you look at my earlier post you can see that gen 2.5 have additional shifting mechanism along with vacuum lines that run to the diff.
Good work!
thanks, I agree. BTW did you do anything to fix the flashing front 4x4 lights?
Toasty
I don't know, i'm either really used to it or i made it just stay solid. it's been so long since i did the swap i can't remember, and it's been since fall that i've wheeled that truck. I'll have to check that out.
nwoods
Dmitry, you seem to be confused about the nature of your rig. It does not actually have a propeller....
eurosonic
My rear end floated down the river for little bit. I got some traction with my front and managed to get out. I'm thinking of doing the propeller retrofit coming out of the rear diff.
nwoods
Speaking of Diff's, there's an excellent chance you submerged your breather tubes. Have you checked for fluid in the lines after that little puddle crossing?
eurosonic
Everything is extended.
Here is a vid that my buddy shot on his quadcopter
darrylkd
