Before:
After:
Stock height, no lift yet (rod or electronic)
Details. Most should be self explanatory, ask if you think I can answer a question for you:
Very low air pressure, required a bit of "foot leverage" to get it started under the tow receiver. I carry a compressor, so as long as the spare doesn't come off the bead I'll be good.
Also, I removed the plastic exhaust trim. The exhaust pipes still look plenty far away for heat to be a non-issue.
Again, stock normal (middle) height.
So far it seems good. Very slight rub in the rear on full/close to full compression (drainage ditch). Also a rub in the front at tight steering angles when in reverse. I'm sure there will be more, and I know I need to do some trimming before serious off-roading, but so far not bad for a 2" bigger tire.
After:
