Capture Colorado 01 TRD Taco - GOAE build
capturecolorado
Hooray bikes!
Just needs paint.
Figured out a way to mount the dual sheer bracket without having to weld it on. Makes installing the bumper easier by tenfold. Also allows modifications to be made to just the swingout whenever needed in the future.
capturecolorado
Hooray bikes!
Thanks guys.
It's quite heavy, I'd say the bumper itself is probably in the 100lb range, so probably close to 140 with the swing out. It's just light enough that I can move it around myself with my bad shoulder.
capturecolorado
Hooray bikes!
Relentless GB DIY kit came last week, tacked it together yesterday and then moved on to wiring up my relay/fuse board that I've been putting off until I had somewhere to hang my lights. The mounting holes on the lower light are slightly off-center, which must change, and the pods aren't aimed yet. But the two 10" bars are wired with each other, so much light.
Relay panel installed. I'll rework my wiring organization into the cab when I add more lights and when I get new Carling switches that I can wire up to the dash circuit. I also plan on having the forward-facing lights have a master shutoff by tapping a signal wire into the high beam signal, and have that control a relay that independently powers the switches for the front lights.
capturecolorado
Hooray bikes!
Here's some crappy cellphone pics of the lighting setup.
Low beams only. These are the Olympus Offroad H4 LED bulbs w/ Anzo housings
High + low
High+low+pods. Pods are angled outward to act as cornering lights, to hopefully allow me to see around switchbacks and hard turns at night.
Lights. All the lights. Two 10" bars, one on the grille hoop, one on the bumper itself, pods, and high beams. The two 10" bars compliment each other very nicely, the upper bar is spot, the lower is spot/flood combo, the spot is aimed higher, centered slightly above the top of the high beam line, and the lower is centered around where the low beams are, it gives a really really nice spread. I drove through Bear Creek canyon the other night and used them before they were aimed better, and it was worlds better than the halogen setup I had on my jeep.
MtnClimber
Ready To Explore!
Wow! Big difference how the pods light up the tree to your right! Major improvement!
Any idea's on how heavy the front bumper weighs in at? (maybe it'd say on the shipping box)
capturecolorado
Hooray bikes!
The shipping weight between the two packages was 120lbs, I kind of doubt that's the actual weight, I can lift it and install it unassisted without issue. It's awkward, but doable.
As a side note, someone take the rear bumper away from me before I throw it away. Damn thing warped and it's eating at my soul.
soonenough
Wow just now checking out your build for the first time, awesome thread so far! Really interested in your relay bank setup. I'm in the same boat as you, big plans for electrical accessories, and currently have a bunch of different wires all over the place with excess zip-tied here and there, etc. Impressive work so far, I'll be following this one. :sombrero:
Also - nice work on the rear bumper. It sounds like you have most of the details worked out, but in case you're still on the fence about the latch, have you checked out the Synergy Suspension latch? Not cheap, but it's what I have on my rear swingout and it's awesome. Really smooth, very stout, super easy to open and close, even one-handed.
http://www.synergymfg.com/Synergy-Universal-Swing-Out-Latch-Assembly-p-19993.html#.U44UYxZNtuY
capturecolorado
Hooray bikes!
Thank you!
For some reason the latch that I used on my personal bumper has been giving me problems, but the latch (same exact one as mine) that I put on the bumper I built for a guy has had no issues whatsoever. I'm now trying to figure out if it's the latch, or something in the geometry of how everything comes together when it's closed. It could simply be that I don't have the swingarm resting on the pad, so it has some vertical movement causing a discrepancy with the adjustment. I think I'm going to experiment with some chunks of HDPE to fill the space and see if that solved my woes, if not I may very well be buying a $125 latch...
After a couple of months of not really doing anything to the truck, mostly due to a combination of not enough time or money... I caught a cold, so I'm taking the time that I can't get out and ride my bike every day to do things I've been meaning to get done for a while.
I burnt in, sanded, and painted the front bumper last week (still trying to find a good chance to take pictures...I like using the parking lot at red rocks, but there's been shows every night). Today I took some LED strips that I had sitting around from when I had my jeep and gave the bed some illumination. There's about 18 feet total of strip, approximately 6' on each bed rail, and 3' on the center two softopper supports. The bed rail lights are waterproof, and because a) I didn't have enough waterproof lights to run on the topper, and b) the underside of the topper is almost always totally dry, I used some non-waterproof lights on the topper.
The whole circuit runs on a 5 amp fuse, I'm going to see if I can get away with less, but I'm not sure just yet. It's powered directly off the battery and I used an illuminated toggle switch with a safety cover in the rearmost driver-side corner of the bed to make sure that the lights don't accidentally get turned on by cargo, it's also in an extremely easy to reach spot, so I can blindly flick them on without issue. The switch cover plate worked out to be perfectly the same height as the bed rail, and tucks into the corner quite effectively.
I wired up the topper lights with a disconnect at the base of the topper, and enough extra wire at each pivot point to allow it to be folded down without issue.
In all (not counting new tools :) ) the total cost of this project was about $20. I already had the LEDs from almost a year ago, I used 18 gauge speaker wire for all the connections, which I already had... So really I just needed to buy a light switch and 130 4" zip ties today.
I went a little overkill on the zip ties.
PICTURE TIME!!
This is how I previously navigated the back of the truck at night... So brutish and caveman-tech; an (admittedly bright) LED flashlight w/ flood. Same settings on the before/after picture both in-camera and editing.
Ta-da!! (seriously, same settings)
Millie approves of her throne.
#ziptieoverkill
Hard to see, but here's the switch. I'll get better detail shots when the sun is up.
I'll be putting these in the cab and wiring them to the dome lights soon, as well. The method of drilling holed in the bed rail and securing the lights with a zip tie seemed to work out well, so I think I'll do similarly to the plastic trim in the cab.
capturecolorado
Hooray bikes!
Boy that sure is super cheap...thanks for spending my money!! :jump:
(order placed).....
Happy to spend where I can :)
Since adding the rear bumper (in general), and specifically the tire carrier, my Thule T2 XTR hitch rack is... well... when it's on, I can't access the bed via. tailgate. Which kind of sucks on trips. So I wanted to be able to haul bikes, and get into the back without having to deal with a bunch of BS.
Initially I was going to build a hitch-inserted swingout, basically a hinged swingarm that attaches to the receiver. I got like 90% of the way through building this yesterday, and got tired of trying to solve stupid problems.
This morning at about 5:30, as I tried to ignore the sun, it occurred to me, that I already have a swingout. It's pretty damn burly, too. Dual sheer, nice bearings, yada yada.
So I grabbed some of the stockpiled steel I had kicking around and cut some stuff up, burned some stuff in, and then came up with this. It's very similar to the setup I had on my Jeep, with exception of the all-in-one design, and it's overall profile. I had something like this on the Jeep, but it was a roof-mounted segment, and then a hitch-mounted one. It was really stable, and worked great for a good period of time.
The insert and vertical piece are 2" square 1/8" wall, and the two horizontal pieces are 1"x2" 1/8" wall. It weighs less than my Thule rack, and is the only one of its kind. I welded on a 6" receiver tube to the swingout, then tied it in further with a piece of 1/4" plate for peace of mind.
The only downside, is that clearance beneath the wheel is 22" on level ground. I would like more, but if I'm honest with myself, I don't need more, it's purely an aesthetic thing at this point. The important thing is that the end of the bar is lower than the top of my antenna, which means I can fit in most parking structures.
Now, I'm not sure if I would want to have it like this for long with 2 bikes and the spare, but for quick access, it's not bad at all, no deflection in the system.. just a little additional strain on the bumper and frame.
Also...
climber-420
damn dood, your truck is legit. love every aspect of it(other than the soft topper, I am a hard shell type of guy). your work is clean, and well thought out. looking forward to what you create next.
jordanP13
