2015 Subaru Outback: The Anti-Wrangler
Hodaka
As Chazz stated, some of the auto transmission Subarus can have a mod wired in that will lock the center diff. Also, certain models came with a rear limited slip (yes, even front on some-but not ones you would normally use off pavement).
Subaru has made many different versions of it's transmissions, including a model with full time AWD with a lockable center diff. Because many of these transmissions share common cases and other parts, combos like full time AWD, lockable center, and selectable high/low range can (and have been) pieced together. Not to mention, there are transfer cases that can bolted in behind the factory transmission, allowing combos with dual transfer case, 4.44 final drive, etc. *some fab work required.
That being said, a Subaru Brat with a mild lift (4"), slightly bigger tires (27" SSR's, IIRC), and a slightly built stock engine did a lot of the Rubicon a number of years ago. I think they ran out of time, and were unable to complete the trail, but they did way more than any of the Jeepers thought was possible.
My own experience with Subarus is similar, as I often get into places that I should not be able to. No damage, no thrashing, just proper driving. I have owned a JKU, and I think the only place I went with it that my Soobs might have had trouble with was a mud hole. And the Jeep almost got stuck there, anyways. The Jeep has more room, gets worse mileage, and makes a better platform for building something more hardcore. Give and take. The Outback is miles ahead for highway and softroading, has a little less room, and can only be upgraded so far without a lot of work. For most people, that's just fine.
Dake21
I think I should re-emphaze that I like Subarus vehicule and do not hate them. I just want to put the record straight. I go wheeling with a guy who owns a forester, great guy and I like his vehicule. he made it trough some mud with highway tires and I wouldn't expect him to succeed.
The comparison is with what the consumer would consider like vehicles in like price range. The average consumer just knows that its AWD, that's it. I believe there is a test out there that was not done by Subaru which took the Outback against Lexus, Audi, Toyota high lines, it showed that the Subaru was the only vehicle that would climb a ramp with only one wheel of traction. I agree, A lot of manufactures use similar systems, but even the engineers at Ford say the electronic portion of Subaru's AWD is very good. Hey, I am not a Subaru fan, but I am not hater of what works.
A Lancer, SX4 and jeep patriot all fall within the price range, but curiously you will never see them in these tests.
Chazz the new subarus all use the same type of system Rover uses - they use brakes to stop wheel spin and push power across open diffs to the other side. XMODE is just computer logic that keeps wheel spin and skid controlled ie wheels keep turning even if the car is sliding say down a hill ie decent control etc. Locking stuff doesn't matter on a vehicle that is 99.99% of the time an on road vehicle however highly reactive systems that can help keep a vehicle pointed in the desired direction on a slick highway is very valued feature which is what Subaru's systems are primarily designed to do.
You want a locking center unit or front or rear locking diffs get a truck. Full disclosure I own a Subaru and my prior Subaru replaced a 4runner. It is what it is. A very capable car I would put my wife and kids in knowing the cars systems are about as good as it gets regarding keeping them safe and helping my wife keep the car on the road and out of the ditch.
Locking isnt really for rock crawling ONLY. When I lock my center diff (acts like a classic 4wd.) I gain a LOT more stability on dirt roads, grass etc. The dirt road I use to go to the gun range during fall becomes like a wet sponge and locking the CD helps a lot. SUV used to have lockers too, but they were replaced by electronics.
I know in Europe you can have a forester with dual range (high and low gear) but for some reason it's not available in North america.
kojackJKU
Autism Family Travellers!
That Forester sounds sweet! The Jeep sounds like my Dyson.
Jason
The ********** jeep driver don't know how to drive. that's a joke right there. He just ********** foots it in. Wrong thing to do in the snow. The roo driver knows how to drive. Jeep owner is a poser.
WagoneerSX4
We had the Baja available in Newfoundland, sure you got your models correct? one of my buddies had one. freaky little rig.
I know we got the baja, in my teens I worked in a factory that made parts for it over here. I was talking about specifically the dual range transfer case option.
kojackJKU
ahhhhh I misunderstood. If there was a dual range trans, Im sure you can source one somewhere. Hell we have skylines GTRs, and other japan only goodies, so I am sure we can get a transmission to fit in a Subaru!
Chazz Layne
Administrator
I am going to love the day when a 3rd party makes a locking diff of some sorts for the roos. Chazz, get to lobbying for it.
If we weren't such a litigious society here in the states I might consider marketing a kit. :(
It's not a diff lock in the STi. It is a Center Diff adjustment knob to send more power to the rear.
Yep, the Foz mod is pretty much the same. I could wire up a knob, but it's automatic decision making skills have been good enough so far that I only really want to override for the 50/50. The "reasearch" thread on this mod was intriguing... they played with different voltages until it was dialed in just right.
It seems weird coming from Jeeps and Land Rovers where the 50/50 split is caused by a physical lockup via lever, to find what's basically a dimmer switch in the Subi's that's technically capable of anything from a 90/10 to 10/90 split. :D
libarata
As soon as your tires spin, you make ice. Plus, jacking your RPMs up like that is horrible on the machinery. Take it slow, take it easy, make your tracks so you can back out when you lose forward momentum.
Fireman78
What is a "Glampground"? I don' t think we have those here in New Mexico. Is that a California thing?
zhukoveli
