TerraLiner:12 m Globally Mobile Beach House/Class-A Crossover w 6x6 Hybrid Drivetrain
thjakits
Hey Bio!
...damn! this thing is going too fast for me!! I keep on reading posts/answers and re-answer by posting and editing as I catch up!
So - I am sorry for much of the parallel posting of stuff and sometimes triple-discussions!
I am better than "hawk circle dive and hit" typing, ......but not much!!
Sometimes I HAVE to get off my ******** and do other stuff in the middle of a post, so it gets posted later too.....
Oh well!! :sombrero:
(1) Here I agree with you, just not regarding the hub-motors part. With Haf-E’s three-motor proposal, there is no reason why all axles and all motors would have to be active all the time. As you rightly suggest, only one “main” motor should be active for most highway driving. All three motors would be chassis-mounted and protected from vibration. But perhaps as you suggest they should be different sizes. You suggested 420 KW overall, so how would you “parse” this power requirement? Two motors 100 KW, and a main drive motor 220 KW?
WRONG! You will have to have all motors active at all times - if not for driving, then for re-gen braking! Remember, NO matter what your final layout will be - center of mass will be roughly somewhere around the middle of the truck. Braking will move a LOT of that to the front - so the FRONT wheels will be doing the majority of the braking (re-gen hopefully!) - you can load the rear-drive motor all the way to actually BLOCK the rear-axle, but it will not increase your braking capability beyond the tire-adhesion at this point - remember the rear wheels will get un-loaded, the front-wheels will get more loaded under braking!
Your front motors (hub or central) need to be able to convert as much as possible into re-gen energy if you want any efficiency from your ride!
You actually should try to design the rig so, that you need friction brakes just for the very last, very slow bit to stop and in very slow terrain - in these areas you do not need super-heavy brakes. In any case, they should be big enough to stop the truck at least ONCE from the worst possible situation: MVGW+a heavy trailer (IF you go for a trailer - design a new one with hub-motors! ...might as well use the trailer braking to charge batteries too!!)
If you want ONE MAIN MOTOR - it has to be able to maintain your "power requirement" sample: longest, heaviest climb at max speed....
IF you stick with your 3-motor layout, there is NO reason why NOT to drive all 3 all the time!
There is NO detriment to that at all - remember these are 3 completely independet drives - no connection what so ever, no twisting and torquing up any transfer box even on blacktop!
Bio - I was all in favor of this configuration and was "fighting" the hub-motors (go back and re-read if you care for!!). ...until I saw the Grimsel Racer and it's hub-motors!! These chage the game totally!
Just don't throw them out quite yet! Have your e-drive specialist engineering friends go through the numbers first!!
IF 3 central motor - ALL the same size
IF 1 MAIN central motor - senough size to maintain most or near max power driving and 4 hub-motor/generators (splitting the rest of the KW capacity) for re-gen braking and AWD-needs. This would give you the superior efficiency of ONE bigger motor (vs. many smaller ones), STILL give you the re-gen braking form the hub-motor/generators (which you will need under hard braking) and AWD when "having fun" (though with the lower efficiency of smaller e-motors, but when? 10% of the driving done!!)
And of course, now that we’re all agreed on the three-motor solution (at least we’ve agreed on this much! ), electronic diff lockers are no longer an issue. Mechanical diff lockers are clearly the optimal solution.
WRONG again! ...see above!
So too, given the three-motor solution, there’s probably no need to debate hub motors mounted inside De-Dion tubes anymore….
GUESS what!!
As for hub motors and water, no worries. That’s not the main concern. As already suggested above in a post quoting dwh, the main concern is shock and vibration. Mounting the electric motors on the chassis ensures that they are relatively insulated from shock and vibration. The Tanami Trail breaks axles; it will probably break electric hub motors, too. Haf-E made the same point. It just seems a complete mistake to put electric hub motors in an overlanding vehicle, even though engineering-lite concept designs like the "OEX-B" by Bekradi, or the “Nimbus” and “Troy” by Galvani, stipulate as much.
SEE previous post!
Oshkosh’s diesel-electric solutions all seem to mount the electric motors on the chassis, and not in the wheels, and no doubt Oshkosh's reasoning about this issue was the same.
What is good for Oskosh is not necessarily good for Terraliner!!
REMEMBER - Oshokosh is promoting to the Military - we don't even know WHAT the military wants or requires (in detail). We only see what Oshkosh thinks is the best solution for the specific Military requirements. Although at this point it seems that the Oskosh approach is a viable solution/option, but the Terraliner requirments afre DEFINITELY different from the military!!
Again, about that 420 KW: you are referring to the total power of the electric motors, right? Not the generator output? So in terms of HP, what I’ve just proposed would mean two electric motors 134 HP each, and one producing about 300 HP – see http://www.rapidtables.com/convert/power/kw-to-hp.htm .
You also proposed that the diesel engine should produce 300 KW, or 400 HP. Same question as I asked earlier: is this the proposed power rating of the diesel engine? Or the KW power output of the attached generator? These will be different, and the KW output of the generator will be lower.
Here the assumption is that a large battery bank will drain more quickly than it’s charged by the 300 KW generator, if all 420 KW of electric motor power were being used. So just a speculative question: how big do you think the diesel engine would have to be, if no battery were intervening at all, as per the Pisten Bully 600 E+ posted earlier in the thread? 420 KW is 563 HP, so certainly at least as big as that, right??? But power is lost via the generator, so…..?
Again: Your Diesel-Generator Unit should provide enough power, so you can accelerate and maintain top speed on the longest, steepest, climb with a Max load on the rig, incl. a possible trailer - WITHOUT any battery assist! A rough calc would put the total weight around 35 tons between truck and heaviest trailer. About 400hp should do the trick (have some truck development engineer run the numbers) - I am taking the Austrian/Italian Brennerpaß as a reference. From my limited experience - that is about the steepest pass which you can do (mostly) at max speed if you have the power. Steeper passes hardly ever have straight enough runs to maintain max speed for more than minute, IF you get there in the first place. Driving slower, needs less power - spare power goes straight into the battery pack and helps you power out of the next switch-back.
Rough idea: 350-400hp (260-300kw) power-plant, 600hp (440kw) max TOTAL e-motor capability.
This way you have some serious power available for some time (depending how full/empty your batteries are)
Actually this is already a bit overboard, but you will need some serious re-gen capability if you want to be able to re-gen to the max!
So gen-mode should be able to push a LOT into the batteries (for serious braking work, like DOWN the steep pass we just climbed up - you will more likely need a serious SuperCondensator bank to catch the massive amount of braking engery coming in!)
You don't want to go over board with the e-power drive mode though, as things tend to break easier the harder you play!!
Many thanks for the suggestions about the modular approach to construction, and designing so that the TerraLiner could be buildable 8 m to 12 m. That’s a nice way of thinking about it, although 12 m sound just way too big….
Look - to you it might seem extreme! BUT a 12m truck will fit 99% of the places a 10m truck goes!!
I know your base spec is a "couple"(elderly, enjoying their retirement, doing crazy stuff in the middle of nowhere... :wings::sombrero: ), but I bet there would be just as many families, bringing their 4 kids or mum and/or dad or grandpa/ma with the 4 kids or....you name it!
THAT's why I suggest the 8-12m approach. Structurally you designg for the "worst" case - 12m.
Then you build them all the same - just shortne the sections between structural columns....
If you are hot for the 10m - non problem! 8m enough - go for it! ALL out - 12m it is!!
5 different lenghts!! Pre-build/prepare different sections and finalise with the choosen length - I think with the price range of this thing you probably will built to order only anyway...
WHICH should be no problem if you have a modular approach to everything on the machine!
4) Interesting comment about there being no need for an auxiliary 20 KW unit; rather, what's needed is proper alignment between main generator output and the size of the battery bank.
However, here I am thinking of egn’s earlier comments in the thread about the insufficiency of the Earthroamer dual-alternator solution. Earthroamer does not provide diesel generators in its expedition motorhomes, because it claims that it’s better to just charge the batteries with dual alternators off the main engine. But as egn and others have pointed out (e.g. Julius), “idling” when parked is illegal in some countries. Whereas running a very silent and sound-protected diesel generator would not be. So egn was quite adamant that the Earthroamer “anti auxiliary generator” stance seemed completely wrong-headed.
What you are in effect proposing by eliminating the 20 KW auxiliary unit is something roughly equivalent to the Earthroamer position. That’s why I’m a bit wary of eliminating the extra 20 KW generator.
Now agreed, the main engine/generator should be soundproofed as far as might prove possible. And perhaps because it’s not a “real” diesel engine, and actually a generator instead, existing legal constraints would not apply?
Bio! FORGET about the Earthroamer and/or idling!! You don't do either!!
First of all, Earthroamer is NOT a hybrid (parallel or serial) - if they have a problem with their alternators - too bad!
They should find a way to install a 5 kw or 10 kw generator!! (Most likely they try, but have a belt slipping problem! Generators of this size tend to need some serious grip!) A 10kw gen normally would go on a PTO or aux drive of the transfer-case or trans. Earthroamer's base-vehicles don't have any of that.
Then - IF they get a 5 or 10 KW gen on the rig - they will need a serious battery bank to be able to take on that kind of charge load!
The Earthroamer is genius development, but at their size storage and weight capacities are limited. For the present Earthroamer line I think a GOOD set of solar-panels, correctly installed and a 5 KW-Honda is all you would need!
As stated before - I believe the lower "efficiency limit" of Diesel-Generators is around 1/4 to 1/3 their rated power.
So - IF we take the 260kw unit from above - you want to run it at a minimum of 65KW output - your challenge is, to design the battery bank to be able to take that as a charge load!! I am sure - this will be a substantial bank, which in turn should enable you to run your household for 24-48 hrs!!
Charging at 65 KW - you are NOT idling you are CHARGING your POWERHOUSE!!!!
Anyway - most of the places where idling would be prohibited would have shore-power. Most places where I would go with Terraliner would not have shorepower within a 1000km radius! Most places I would go - NO one would care if I idle, 1/4 run or let the Diesel sing!!
Once Terraliners (or similar) become reality, all these regulations will change anyway. Can't imagine that people would be stupid enough to prohibit a big/efficient/clean/fast (short run time to full charge) Generator in favor of a smaller nad therfor less efficient gen-set that needs a lot longer ot charge your banks....
Then, .....you never know!
Glad to see that you like the “engine/generator on a slide out tray” idea. That modularity alone would be very attractive, because the mechanical engine will probably be the most fault-prone element in the whole system. MAN designs its SX series trucks to have a service life of 30 years, but one wonders whether this includes the engine?
Depending on the brand and systems (pre-heat, pre-oil, computerized run control) - your IC-engine will probably be just as sturdy and long living as your generator!!
Most likely out living the rest of the rig. I'd say IS would be the most maintenance intensive part of the drive-chassis.
Of course a lot depends on your diligence with fuel/oil quality and changes.
WHICH reminds me: YOU NEED to provide a "fuel-quality assurance system"!!! You won't believe how Diesel quality changes all over the globe - ....and what crap people sell for Diesel in places!!
NOTHING faster to stop your trip than contaminated fuel in the system!!
Look, if YOU don't skimp on quality motor/gen, axles - most Terraliner owners will NEVER outlive these parts!! A good set should go 750-1000k km without a sweat!
E.g. Caterpillar!! Their big D11 goes through an engine rebuild every couple thousand hours - for the abuse it suffers from the hydraulic pumps it drives.
On the new D7E-drive - the Diesel hardly wears!! It is computer controlled according to the e-motor power requirements and totally de-coupled from everything but the generator. The computer decides when it is at max power, no chance to overload and abuse!! (Essentially the same as on the new Pistenbullys you mentioned)
egn advocated just such a “castrated” 8x8 earlier in the thread:.....
I'd rather say "alleviated!"
And the weight of the lithium-ion batteries and the electric motors will be distributed more evenly throughout the vehicle.
WHAT?? You STILL din't check out the new Japanese Carbon-Carbon batteries?? 3x as many charges before they are dead, 20x faster charge rate, no minimum voltage to maintain at discharge, not heat-issues and proposed for vehicles!! Check it out:
http://www.gizmag.com/dual-carbon-fast-charging-battery/32121/
Carbon-Ceramic brakes from Brembo
I may be wrong - but I believe that Ceramic brakes (disks) are mostly Racing-equipment exclusively - they need to get to a serious high temperature before they work!!
As mentioned before - with a excellent re-gen configuration, you friction-brake needs should be dramatically reduced compared to a conventional drive truck....
Brembo's are good, but about 70% of the price you pay for the brand-name!!
Perhaps this is a really stupid question: can portals work with Independent Suspension? Or is the natural pairing Straight-Axle + Portals?
I never saw one, but I am sure if you insisted one could be built - imagine the hub of a Solid Portal-axle and the (usually) wishbones of a IS mounted on top and middle of the hub, instead on top and bottom. You get some serious ground clearance increase, STILL have the "problem" that the IS only raises the wheel and not the whole center of the axle/truck, and I would suggest it will need VERY MASSIVE wishbones ot deal with the added bending forces from the offset mounting relative to the wheel.
Whatever weight -advantage you got from the regular IS over the SA will certainly be gone.....
I'd say if this had some serious merit, we would have seen it somewhere - ...anyone..??
Thanks for the super-cool video about regenerative braking in Bosch’s parallel hybrid system. So cool, it deserves to be posted again:
The Kudos need to go to CAMPO - he brought it back from the last Truck Expo!! (I think it was Campo!! ...?)
Of course regenerative braking has to be part of the system, with the electric motors switching over to act as generators. I posted something earlier in the thread on the topic, and some links to websites that explained that although simple in concept, in actual practice a bit more complicated to implement – .....
You have NO idea!! IF you ever ACTUALLY get Terraliner built - this will be one of the VERY big challenges!! You have MASSIVE amounts of electric energy going back and forth through the drive system and constantly changing!! To make this work you will need to engange some top engineers in the field!!
If you don't intend to ever build one - at least talk to some specialist engineer - so you cna make at least some smart comments to the control system!:sombrero:
If someone is interested in the technical aspect of Terraliner - THIS will be centeral conversation piece!!!
Where did you find the image of that integrated MAN-KAT?
Damn if I remember!! I was looking for "MAN/KAT 6 wheeler" on google images or "MAN/KAT 6 wheeler Explorer" or either without the MAN/KAT...
[I like the draw-bar across th efront of the cage doing double-duty as a bumper!!]
Pretty much the only thing I have “concerns” about, regarding SA, is the turning radius. The G-wagen has a notoriously wretched turning radius because it’s SA. Oshkosh emphasizes the turning radius advantages of IS in the following video:
Of course TAK-4 will show you the advantages of their turning radius!! They want to sell the equipment!!
They don't have to tell you, that a SA can turn just as tight as a IS!!
Look, the wheel is attached to the whole system at the hub. Wether that hub is connected to a IS (via wishbone or a trailing arm or ...?) or a SA doesn't matter!
The possible steering lock is determined by the way the drive-power is past through to the wheel - normally this is a CV-joint or a U-joint (cardan joint). At this size vehicle most likely a U-joint. Now naturally there are limits on how much you can "tilt" that joint before it starts to bind up. The longer and thinner the U-joint forks or the deeper relieved the ball pockets on a CV-joint, the greater the angle, the better the steering lock! .....and the more prone to snap!!
The question is just about the Joint, how much power, how much risk.
NOT if IS or AS!!
Bio, watch out!! Company brochures are fantastic (sometimes REALLY FANTASYtastic!) and sometimes they are so convincing that you become literally a believer!!
I went through that with the (in)famous K&N air-filters. Absolutely fantasytastic - and it made all perfect sense!!
Until someone finally put some realworld tests and analysis on paper!!
[I don't think K&N makes replacement filters for Diesel-Generators, so this is irrelevant for Terraliner - if you want the story in detail, let me know and I sned you the links!]
[Just as a starter - K&N tells you that thir filters flow 30% better than the stock paper/tissue filters. They also tell you, that their filters start to filter really well once soem serious dirt is on them!! oiled cotton filters.... - Tests show that when fresh their filtering is quite miserable until they get plugged up with some dirt - by then the 30% (...that are less in the test) are mostly gone! Now 30% more than a stock filter sounds like a lot of added power! ...until you realise (another serious of tests...) that in about 99% of all cases the airfilter accounts only for 2-5% of ALL of the intake restrictions!! So - how much overall increase in airflow do you get from those 30% of the 2-5%?? Do the math and you get a 0.7-2% increase of flow for the price of loads of dirt in the engine!!
You want more flow - start to clean up the intake path!! .....loads of samples available on: http://origin.autospeed.com/ ]
BTW - as mentioned somewhere above or before: I have nothing against IS, contrary, it is ecellent, just not the BEST system for Terraliner (in my book).
There are properties of a IS that a perfect and intentional for other applications, but detrimental for what I think Terraliner needs/wants.
'nough for tonight!!
thjakits :coffee:
biotect
Designer
Hey Bio!
Hey thjakits,
Remember, you are dealing with a cybernetically enhanced Biotect:
As for the quantity of my output: I type very fast. touch-typist, over 100 WPM, no errors. Mom was/is a bit of a feminist, and insisted that I take a typing course when I was 14. So I don't "hunt and peck" with just two fingers. Also speed-read (over 2000 WPM), and I use DevonThink to organize my research -- see http://www.devontechnologies.com/products/devonthink/overview.html and http://www.devontechnologies.com/solutions.html . So let's just say that my blogging is "cybernetically enhanced"....:sombrero:
:hehe:
But seriously, it's New Year's Eve, and for the rest of the day (and night) I am going to take a bit of a break. Will try to respond to your last three posts after New Year's. Following New Years I have a few more days available to participate intensively in the thread, and then I'm afraid it's back to academic commitments at Art College. I'll need to begin preparing for the new term. So there will be another "lull" in my participation, between roughly January 6th and March 19th, when I have spring break. I'll have a good chunk of time to participate during spring break: from March 19th until April 11th. But in January, February, and most of March, this thread should return to a more "normal" and sedate speed, once you and I are no longer engaged in lightning fast exchanges that cover just about everything......:sombrero:
All best wishes,
Biotect
biotect
Designer
Its a good job we dont know each other in real life!!
Been in management roles myself, all right to start with, but in the end i hated it with a passion, so i'll stick with being told what to do now if you don't mind! My CV is definately off the table!
Hi optimus,
Actually, it might be kind of fun to meet up (say next autumn....?), and compare notes about how wretched and soul-destroying management can be. Much, much better to be a "professional day-dreamer"....:) -- http://www.expeditionportal.com/forum/members/98458-optimusprime . Here is one of my favorite songs, no matter how "pop":
The worst part about management was disciplining people who simply had no sense at all, and little ability to be minimally civil and professional. Setting goals and inspiring proactive enthusiasm was the good part. But at times I felt like a nanny, dealing with adults stuck in suspended adolescence. Or adults whose sense of self was so weak and fragile, that they had extreme "fight" reactions to minor problems or criticisms. Gosh, the list is endless. Before I was bumped up to management I did not consider myself as possessing highly developed "people skills". But turns out that all that was really required is being more sane, calm, and civil than everyone else. And, I guess, more organized.
All best wishes,
Biotect
optimusprime
Proffessional daydreamer.
Hi optimus,
All best wishes,
Biotect
. Man i love love that song!
My music taste is eclectic ( or just plain wierd to my kids!) so yes its a bit cheesey,but who cares!?!
As for dealing with with staff who,to be diplomatic,are lacking in the 'blindingly obvious stakes' ...... If we ever meet,remind me to tell you about the highly intelligent driver i had who drove a fully laden transit van onto the beach ( with obvious consequences) because someone told him it would be 'alright' ........that was laugh ... No really .......
biotect
Designer
The TerraLiner Pop-Up
Hi thjakits,
Before responding to your most recent posts, I want to answer a question you asked a while back, in relation to stabilizing outrigger jacks:
How tall do you want to go?”
Answer: very tall. I want a double-height interior, and not a 1 ½ height interior, as per UniCats, or the one Armadillo shown earlier in the thread.
There are two ways to increase interior space in a motorhome: slide-outs, or pop-ups. Apart from the swing-outs at the back that I have already illustrated, I strongly prefer a pop-up, because a pop-up has the potential to give the motorhome a feeling of tremendous New-York-loft-like interior volume. I really admire UniCat for coming up with this alternative solution to slide-outs. I just think that they did not push it far enough.
So what I’m thinking of is something along the following lines:
Just joking……:sombrero:
CONTINUED IN NEXT POST
biotect
Designer
CONTINUED FOM PREVIOUS POST
1. Celebrity Two-Story Trailers
More seriously, there do exist many contemporary examples of pop-ups that have full-height second floors.
For instance, Will Smith's trailer – see http://www.dailymail.co.uk/tvshowbi...York-block-2m-trailer-Men-In-Black-3-set.html , http://www.dailymail.co.uk/tvshowbi...urious-2-5-million-double-decker-trailer.html , http://www.cbsnews.com/media/7-incredible-multimillion-dollar-motorhomes/5/ , http://www.businessinsider.com/will-smith-trailer-2011-5?op=1&IR=T , http://www.businessinsider.com/inside-will-smiths-25-million-2-story-movie-trailer-2013-10?IR=T , http://gothamist.com/2011/05/12/will_smiths_massive_trailer_evicted.php , and http://abcnews.go.com/GMA/video/lavish-celebrity-trailers-smith-simon-cowell-asthon-kutcher-14931631 :
will-smith-mobile-home-hgtv-png.jpg article-2461616-18C0DFB400000578-608_634x306.jpg inside-will-smiths-luxurious-25-million-2-story-movie-trailer.jpg
GETTIN+BIGGY+Will+Smith+massive+double+decker+bFNYychsfSwl.jpg article-2461616-18C0DFB800000578-522_634x355.jpg will-smith-trailer-1.jpg
article-1385926-0BFFE40900000578-562_634x516.jpg article-1385926-0BFFE0C100000578-989_634x486.jpg article-1385926-0BFFE5F000000578-718_634x537.jpg
biotect
Designer
it-has-a-full-size-refrigerator.jpg another-view-of-the-kitchen.jpg the-kitchen.jpg
and-polished-wood-floors.jpg and-tons-of-storage-space.jpg the-spiral-staircase.jpg
biotect
Designer
maxresdefault.jpg article-0-18C0DFD800000578-650_634x356.jpg article-2461616-18C0DFC100000578-225_634x356.jpg
image.jpg screen shot 2013-10-14 at 10.38.327 am.jpg screen shot 2013-10-14 at 10.39.27 am.jpg
article-0-18C0DFE300000578-381_634x355.jpg screen shot 2013-10-14 at 10.50.25 am.png.jpg screen shot 2013-10-14 at 10.59.44 am.png.jpg
biotect
Designer
article-2461616-18C0DFB000000578-122_634x356.jpg screen shot 2013-10-14 at 12.10.15 pm.jpg article-2461616-18C0DFCB00000578-5_634x356.jpg
screen shot 2013-10-14 at 11.03.09 am.png.jpg screen shot 2013-10-14 at 11.03.50 am.png.jpg screen shot 2013-10-14 at 12.55.13 pm.png.jpg
The first set of interior images in post #1134 are from 2011, when even with all the money in the world, Will Smith could not seem to find motorhome interior designers able to deliver anything other than “American-colonial grandma's kitchen”.
The more elegant interior images in the second and third sets are from 2013, when some elements seem to have been replaced or modified, for instance, the surfacing of the staircase, the addition of some rugs, etc. But colonial-kitsch kitchen cupboards remained….
biotect
Designer
And here are some videos of Will Smith's trailer:
biotect
Designer
Recently Simon Cowell took over Will Smith's trailer, and thankfully replaced the American colonial-kitsch decor with elements that are a much more modern, e.g. new kitchen cupboards, a new kitchen countertop and splashback, etc. – see http://www.dailymail.co.uk/tvshowbi...imon-Cowells-2m-1200-square-foot-trailer.html , http://videos.hgtv.com/video/simon-cowell's-motor-home-0199720 , and http://www.bing.com/videos/watch/video/simon-cowell-shows-off-his-two-story-trailer/zgw7iqmo :
article-2194234-14B55C89000005DC-787_634x400.jpg article-2194234-14B55CFA000005DC-710_634x400.jpg article-2194234-14B55D3E000005DC-793_634x400.jpg
article-2194234-14B55D06000005DC-564_634x400.jpg article-2194234-14B55D66000005DC-964_634x400.jpg article-2194234-14B55CED000005DC-198_634x400.jpg
article-2194234-14B55C6F000005DC-401_634x400.jpg article-2194234-14B55D32000005DC-438_634x400.jpg
article-2194234-14B55DF6000005DC-963_306x300.jpg article-2194234-14B55E03000005DC-894_306x300.jpg
Finally, the trailer's interior matches the exterior…..
Below, skip ahead to about 1:30 into the video:
biotect
Designer
Then there's Vin Diesel's trailer – see http://carproperty.com/vin-diesel-s-1-million-dollar-two-story-mobile-home-trailer-ad26372217.htm , http://www.dailymail.co.uk/tvshowbiz/article-2119733/Vin-Diesels-storey-1-1million-trailer.html , http://videos.hgtv.com/video/vin-diesel's-mega-motor-home-0179777 , and http://www.ulive.com/video/vin-diesels-mega-motor-home :
2217_20120509380938x8Uk9.jpg article-2119733-124F65D5000005DC-335_634x318.jpg 2217_20120509370937RYCBF.jpg
article-2119733-124F6629000005DC-684_634x356.jpg 2217_201205093809384uTar.jpg article-2119733-124F6639000005DC-506_634x356.jpg
2217_20120509380938fQ9R0.jpg 2217_20120509390939Fra08.jpg 2217_201205093609362SyDF.jpg
Skip ahead about 8:30 into the video:
biotect
Designer
2. Anderson Mobile Estates
The company that manufactures most of these double-height mega-trailers for the movie industry is called “Anderson Mobile Estates” – see http://www.andersonmobileestates.com , http://www.andersonmobileestates.com/home.php , http://www.andersonmobileestates.com/special.php , http://www.andersonmobileestates.com/trailers.php , http://www.andersonmobileestates.com/video.php , http://www.andersonmobileestates.com/downloads.php , http://www.andersonmobileestates.com/documents/brochure.pdf , http://www.examiner.com/article/ron-anderson-s-mobile-estates-bring-the-heat-to-hollywood , http://www.examiner.com/slideshow/ron-anderson-s-mobile-estates-bring-the-heat-to-hollywood , http://www.examiner.com/article/the-world-s-best-mega-rv-trailers , http://www.examiner.com/slideshow/the-world-s-best-mega-rv-trailers , and https://www.youtube.com/user/AndersonTrailers :
There is a full gallery of images of Anderson trailers at http://www.andersonmobileestates.com/gallery.php , http://www.andersonmobileestates.com/trailer-heat.php , http://www.andersonmobileestates.com/trailer-studio.php , http://www.andersonmobileestates.com/trailer-babygirl.php , http://www.andersonmobileestates.com/trailer-aspen.php ,http://www.andersonmobileestates.com/trailer-mobilec.php , http://www.andersonmobileestates.com/trailer-demo.php , http://www.andersonmobileestates.com/coach-accessh.php , and http://www.andersonmobileestates.com/coach-magicbus.php .
The quality of the photos on the Anderson website is much better than most of those posted above, many of which were simply “lifted” from HGTV broadcasts. The images on the Anderson website are also very easily downloadable as complete “photo packages”. Below are some of my favorites, most of them images of the second-story levels in these trailers.
biotect
Designer
First off, here's Will Smith's/Simon Cowell's “The Heat” trailer, but this time in super-high definition:
On the Anderson Mobile Estates website, some of these are 100 MB tiff files!
