Group-buy Pull-Pal: Ends 1/26/15
flyingwil
Thanks for all the orders. Pull-Pal is expecting to have these shihpped out to us on the 6th, so we should be supper accurate in saying these will ship out on or about the 11th.:victory:
Fzzt
I have a regular arb winch accessory kit (tree strap, couple shackles, 1 pulley, winch extension strap). Do I need anything extra or special for use with the pull pal?
Oh, using stock warn cable on my M8000.
Thanks.
Fzzt
Good call. I've got an old movers pad for use as a damper, when it's not the extra cushion under my sleeping bag.
Now to figure out where it's going to live on the truck.
flyingwil
Thanks.
Sounds like you have your bases covered. Another great item to have is a winch damper:
http://www.sierraexpeditions.com/index.php?l=product_detail&p=458
Basically the only thing you NEED to hook up the Pull-Pal is a D-Ring Shackle. As Nic pointed out it is a good idea to have damper on your winchline for safety as well.
abctrash
