COMEUP Winch Official Thread
COMEUP
Supporting Sponsor - COMEUP Winches
Time to spotlight one of our popular winches.
SEAL Gen2 9.5rsi
This is one of our most popular winches for the offroad community because of its size and pulling power. It's tough, fast, and strong. Features a wireless remote and comes with 100' Synthetic winch rope.
•12V DC severe duty winch rated at 9,500 lb pulling meets or exceeds your expectations.
•Heavy duty series wound motor equipped with thermal switch alters when motor is over-heating.
•4 equally positioned pin holes with a stainless steel ergonomic T-handle make it possible to clock in 90 degree Increments.
•Water-proof remote control with thermometric LED indicator w/5 m cord
•Tough aluminum die cast housings withstand strength of 2.0 x rated load of winch
•The U.S. Germany, U.K. France, etc patented mechanical cone brake outside the drum expedites heat dispersion. The greater the load on the rope, the greater amount of braking is generated by the mechanism.
•Meets SAE J706, CE Machinery Directive 2006/42/EC and CE Electromagnetic Compatibility Directive 2004/108/EC.
Specifications:
Rated Line Pull 9,500 lbs (4,309 kg) single line
Motor 5.0 hp / 3,730 w 12V Series Wound
Gear Ratio 3-Stage Planetary 159:1
Clutch (freespooling) Rotating Ring Gear
Brake (outside the drum) Automatic, full load CBS (Cone Brake Structure)
Winch Construction Aluminum Die Cast Housing with Steel Drum
Drum Size 2.5" x 9" (63.5 x 228 mm)
Control Both built-in digital two way signal wireless remote control and waterproof remote with thermometric indicator LED w/17' (5 m) cord
Rope Type Synthetic Rope SK-75
Rope Size 3/8" x 100' (10 mm x 30.5 m)
Mounting Bolt Pattern 10" x 4.5" (254 x 114 mm)
Winch Weight 61.7 lb (28 kg)
Gross Weigh 89.1 lb (40.5 kg)
Warranty Limited lifetime warranty for mechanical components, three (3) year warranty for electrical components
Box Dimensions 26.9" x 8.2" x 16.9" (682 x 209 x 430 mm )
Get it here:
http://shop.comeupusa.com/p/seal-gen2-9-5rs-12v-winch?pp=12
Beowulf
What is the range of the wireless remote. I believe the most beneficial aspect of a wireless remote is setting a pul-pall solo. To make sure one gets the best and longest pull using the anchor, most are going to extend the line out as far as their winch line will allow.
COMEUP
It's time to spotlight another winch. When you're looking for lots of power with super fast line speed check out the Blazer Championship winch from ComeUp. This is a winch that has been proven in the Rain Forest Challenge where the conditions are extreme and the demands are high.
To give you an idea of how fast this winch is here are a couple popular winches to compare to. (numbers are for first layer pull)
Warn Zeon 10-S: 33fpm
ComeUp SEAL Gen2 9.5RS: 63.3fpm
Warn 8274-50: 79.3fpm
ComeUp Blazer:164fpm
•Dual motors and dual sealed contactors offer ultimate performance, speed and power in the worlds toughest winch challenge competitions
•7.0 hp series wound motors with thermal protection switch.
•3 stage spur gear train and upright housing are extreme rugged.
•Fastest retrieval speed of 50 meter per minute.
•Ratchet brake outside the drum expedites heat dispersion and also makes the winch ideal for use with synthetic rope.
•Air free-spooling for rapid and easy rope payout
•Submersible sealed contactor
•63.5 mm diameter x 290 mm long drum is suitable for synthetic rope of 11 mm x 46 m
•Water-proof remote control with thermometric LED indicator alerts when motor overheating.
•Hawse fairlead supplied for recommended synthetic rope
Check out more details on the specs and features and other highlights of this awesome winch at the Blazer home page.http://www.comeupwinch-blazer.com/index.php
COMEUP
Maybe your not competing in the Rain Forest Challenge, but you need a fast winch to get you through the bogs of Cape York, or across the flashflood plane in Southern Utah during your weekend adventure. The new SEAL Gen 2 9.5RSI is the winch to do it with impressive specs and features, fast line speed, and the "Intelligence Dashboard" to keep you informed of your vehicles batter condition in real time.
SEAL Gen2 9.5RSI
•Heavy duty series wound motor equipped with thermal protection switch alters.
•4 equally positioned pin holes with a stainless steel ergonomic T-handle make it possible to reposition in 90 degree increments.
•Both built-in digital signal two ways wireless remote control and wired water-proof remote control
•Cutout switch activates or deactivates the winch.
•A 12 strand construction synthetic rope coated to improve abrasion and has no water absorption.
•The U.S. Germany, U.K. France, etc patented mechanical cone brake outside the drum expedites heat dispersion and also makes the winch ideal for use with synthetic rope.
•Meet SAE J706, CE Machinery Directive 2006/42/EC and CE Electromagnetic Compatibility Directive 2004/108/EC.
texascrane
Just ordered a seal gen 2 9.5rs for my 100 series. Looking forward to getting it installed and hopefully having to actually use it very rarely.
Scott Brady
Founder
I cleaned up a few posts. Interesting to see people comment negatively about a product they have never used.
I trusted my life to these winches, crossing Antarctica (twice). The winches were also purchased, not sponsored. . .
I also run a ComeUp winch on my daily driver (also paid for).
This is not intended as an exclusive endorsement, as I also run other winches on other vehicles. However, ComeUp is certainly a quality brand.
Box Rocket
Did a little playing around with the new winch yesterday. There wan't anything really gnarly on the trail where we were so we just found some steep, loose hills. Gave me a chance to try out line speed and general workings of the Gen2 9.5rs.
COMEUP
Congratulations to Ben Swain from Slee Off Road and the rest of the crew for their Dirt Riot Mountain Series Championship win!!! Amidst many challenges just to be ready for Dirt Riot Race #3 in Grand Junction, Co they came out with a victory and enough points to claim the Dirt Riot Championship. They've been running a ComeUp Winch on their Ultra4 race car. For a team that expects only the best and performs at the top of their game, COMEUP is pleased to be a part of their great setup. Congrats again for the win !!! Slee Off-Road
Box Rocket
I sank the 80 up to the frame in a muddy riverbed over the weekend. It was a good test for my SEAL 9.5rs since my 80 is on the heavy side and most people prefer a 12K lb winch on the 80s. Well we did one single line pull and the winch had no problem pulling me out even though we had tried to snatch the truck out with a strap and my buddies 200 series. During the snatch attempts you couldn't even feel the strap go tight, the truck didn't even budge. I was stoked that the winch had no trouble getting us out. I'm really impressed with these winches.
COMEUP
Anyone in the PNW that can come by Mule Expedition Outfitters this Saturday (Sept 19) in Issaquah, WA will be able to learn some good stuff about winch recovery in the winch recovery class being taught by Marc Bowers and we'll answer any questions you have about our winches. Should be a great time.
Petersmithinak
