Post up your drawer/storage system
Yuman Desert Rat
The tiedowns can be had by a myriad of manufacturers. Mac's custom tiedowns, Coretrax just to name a couple. There are plenty of off brands as well if you search eBay and Amazon.
GP'd
@GP'd
Couple questions.
1. Where are you getting the aircraft tie down railing.
2. Do you keep the jack without the wheels all the time? Did you do that for a reason? Weight?
I keep a full-sized 3ton jack in my truck too. Wheels still attached though. We also keep a couple of blocks to assist in height where the jack fails.
Macs Tie Downs (VersaTie Track) : http://www.macscustomtiedowns.com/category/VersaTie
There are a lot of after market skids out there also. (Search Harbor Freight 1.5 Ton Skid) Some keeping the wheels, some without :
https://www.ruffstuffspecialties.com/catalog/R1792.html
http://www.c4fabworks.com/Harbor_Freight_Jack_Mount_p/cff-001-001.htm
When I built the skid I set it up to allow the wheel to be attached in the front, but to be honest, got 90% of the way to complete and never finished the project. I've had zero issue sliding the jack around even on concrete so haven't felt the need. I keep a couple of wood blocks in the jeep as well, but someday will built an extension for the cup.
don simon
Mine's coming to an end at the moment. I have a permanent bed and improved storage without losing much space. As the storage has improved, I can live with losing a little space.
94storage by Simon Carter, en Flickr
The bed frame simply slides out.
95storage by Simon Carter, en Flickr
And then slides back in when not needed.
98storage by Simon Carter, en Flickr
The kitchen slides out from underneath the unit, as does a table on the other side.
66storage by Simon Carter, en Flickr
And a barbecue that we custom made sits on the rear for space saving carriage.
73storage by Simon Carter, en Flickr
79storage by Simon Carter, en Flickr
Barbecue makes a perfect firepit for sitting around on these cold evening while taking a beer. Obviously you always need something to get those beers open.
63storage by Simon Carter, en Flickr
The whole set up.
28storage by Simon Carter, en Flickr
Now looking at a full length roofrack that will accommodate a rear mounted awning and roof tent.
jswift716
The whole set up.
this is awesome, i think i need to revamp my xj cargo sketches
Xterabl
Wow don simon that's a lot of cool factors in one build.
Basil, what is that solid wood on your face boards?
If so, what kind?
It almost looks like walnut...but that'd be $$$$$
Building up for a long arctic trip and tight on space I thought I would give this a go!!
A Regular heavy duty two drawer filing cabinet, and I must say it worked out really great in the back of my JK!!
ImageUploadedByTapatalk1442149463.241943.jpgImageUploadedByTapatalk1442149481.476109.jpg
There's about 40lbs of tools in the bottom drawer..
ImageUploadedByTapatalk1442149496.741271.jpgImageUploadedByTapatalk1442149514.610237.jpg
don simon
Today's fettling has seen the introduction of a hinge to provide access to the space between the box and wheel arch, and it worked first time. :)
100storage by Simon Carter, en Flickr
Everything fits.
Everything works.
Time to disassemble, sand it and finish any rough edges and then treat it before reinstalling and securing it into place. Even though it's removable I'm going to keep it there as boot space is still useable and who knows when I'll want a cup of coffee or a quick siesta.
Then it's off to test it and that could mean popping down to http://www.adventureoverlandshow.net/ for the weekend.
sepudo
MFWIC
a different platform set up.
hey all,
first time poster, been reading for awhile.
been camping for about 2 years and reading all the overlanding info is addicting...so i've built a very modest but function for my needs set up and wanted to share.
it's for softroading and glamping so far with the frequent trip to the beach or park with my four legged co-pilot.
start with a clean slate in my Honda Element by removing the seats.
iPNc3B3Q0mMEu4xWSyZEbCuluqai4G2cidnYB2igmSMcxriHbOjZu1KyeyOzaFt8Oq6kAJHn-hMRwgqb8zkSopciYKlZvOT84V1W2MDge_5acxTAXACg4AnDwXPj2n3jlXJQnnaTH__lEItnaeHOnQr8dsBsko8QtOO3D6sDV9aS3t01Sl7NoMrMwpnwWOO0AJccXedUGmr09umy17Et8d1aPzCO962l8Tx0U5YjNHidXGJwI1klfClgNI1i9VrTnX5zrCMYUmT1BMc5HaRo5H6rcWf9VBWZqCwNbq2ylit58xsnHvTc8X5lSt6L7YsfngMrWrSl1bYPG-4QUC7H4_Rv9r2XmfkbZqHzmNKDu_QKJvf2Q3YYldsZyjmkX6nQyJIT347_wSFZasGJj0gmP4ojyjMdQXEZlGiYMPSnSNqXOv5C2yX-48eLPY5oKLVN3eSZmYTsXKk6zq8SFKBHowR2OCXp1-GQQg-srZM8g6XDUdvoQXwvzhgc4nHvbDyPOCoXkxn17bYlyAXvuopIN9Z1Apm4QrmA_K-h6pEGC1Qf=w1284-h722-no
built wire basket and platform support
dxc822BAOC2zt8ilMEVoNoBDp7MWzDrN7E7R4pzt4odT1O9pOfg-BeLkbR-7hFhoL09yxpHgVgrhdQ0oLA3BgWzmgcb8n0eIPoTpwv-i9PyoN2wPRrRJ10RarIQXXH1lhkxxi8v2tmvSY0NSLSv3xWaACOqYoyjh6W8Rk4nZE6f36ypsPETAgoy3ASvQLqwhI_mD3meJwCVGl4gBd2SbdnXSJTAOQb5lEs28WjcSH8PntK5j6elpH-8zkfn4YLCLArAs4VQGXI38q6AKmT1Qo0JkGncF0JEEuUG8Ccere_Tgnl_6hahRug1V_lvqWX75spDN3d6j6IncCtr5W-uxun5VGyua6WNx-xqYULCJjOLqETk0mEj3YI0R5gteIeDRq_sN-p8SvDbqlD1Q034WjiL-9XcS56pzZHImbfP5Y5khI1u-7oUfNKP_XVAzGb2krKDFa_3J_tF6O5Y3gkutZLzeFWIsl2JDQe7PAuQpcj4BdNj1n80wWM_fZR4_431ca5Xewe0BYCfRo46-1EakxJUl0X6WqEys4L5I605-_1JC=w1284-h722-no
added a plywood/piano hinge bed support
1infvh-vFnbD9da4M9qAbzvFMIkgmFPz21B7qYsz3rgAGe6grxW1f192xYrw2ghc1SfFJSqFUKJPwKN8BFPI63NoXtu8SkTUq2hAcHcdOncwmFKWDtI5IjFjbQaHYeU3a2KhfJujc5Qo0jw7wfol7iT6RlniDFIapeWS87gXVskuTj69ze6JxnYUMR8lTqY8X5eakcIkQv8tqLYTmr-n4K7qMEXby--KpUdJ8GsXP6c-3-ne2bYQvDs2f6OqBn8IukMLxw7lxBujSNNjTgLKR9-SmJp-RPFWOArKtcMqn_xFNTskFUplKtMxjiHmCRgruabqV7_HOmdShLECeuBk0QMuQUEUeztzBzWB-wnnv3fUJYGwsMS8nmj8-KdU4c5BX1ZsvU8mxmMtzm4ftOCJ-B8XQZ9yecuo-EyqEjji9ZM1jwIsc51sBPb4najMwyFexk8jpGX8JWXeC1kojboLFrPr3ISb64dRMNfOWyyc20x9kTCzFqNk1mxORWRs-zp4Px6EgV2KOnWMiOcSBUcws1NE4QpdQk4Cvk7qG_1xX4i5=w1284-h722-no
can be positioned in a lounging position for chillin at the beach or park
yL27rKQtN9cZ6KzR1407YjX9wQW8-VoOMMKGdRA7uBBFsgv7gJ5cyGcGecNhK4ST3R9SyOl1c2bt_PKInHsS-VaqZdnuTNNNkXLua8U7fuDtpEBEucvQwrKWIw9UC1yv7VSbtanGQYW32HXiPPxnLXKZVx4fF74dyt65CxE71O86JMtY6spQJC8vy0gsy1tCPIspiKJck7A-7b3yf4bYxM0Zc9h-JYlgq7AQ_yQPmkpL7V41RsgZnsy956T8AhTBJvOadqu7zo9fvP-aiJb0VFKXzSmmDw-ROtOBD5V_dfTbMLT2huC2OwTQDvBOprlJEyuVlhjtvqKv9XTxfwDS_OVmTFga_7ndg5jn0F0HWrjflXJIKgYCJDYFwj0gKXgIRUQen3lTY6eiRO6qwWA886YybyPbfBNHCloyDlOFujvGOcWvJ6KPtdh2LXZBt4ZXzolHKK1FX2Bi0bvB0RPcJEqE2j5D54HWB4Uo35gZJtndNwwR8agVRUyin8SXHJPVWiCNSkT1i8dQ6dbyVDLVjm3Os3EV9boO8TQ_KDciIN55=w1284-h722-no
made and sewed foam bed cushion
BGft8I6Z8lmEfNECx_DRZg72sbye9Dgx7eUtabeZ0RTSEzWGilTStaXcJY5z7TvP1oee4n3QGlbRPgJ5BbdDJGSGEN97iqwTvhDWNepjciqCdtVkX8Rkn2BR72hI2wOyHvIOos7HGLq_zQ5lFFbNDziIO1234Kz9N3L8nzD3-Y6htJhCkomV6eTo0PjolocJT3OnE2e7xFduAl9clfYdZ_mt7QJCTDAwFPUp8x-GHt5xrwKWBs8Fx346SSKCoPZUtn2T9q0PP_JmLMgzQQQhizO_YvxRFg8phZNXsvVJ2o-aHhLxnkuKhAxQGjW2q-OXyiThSNUpWlkfSVM6OnE8Sz_Fmh6ONOpDIGllxndcfOVFDMimhPFgE_VMXHiGnLC11zAV8ZCspt57uq31FMwX83HJrFGOadmMOoJqDl6-qIQnq-HQi7IYOtmoZ4GE2baTF652uzM_DiaC4XfvQ_eVJwB-qfKlSGSg8H5W9NDNFiFOL8qAf1yntQwh6Uzbhl9hO7UO7D8iWtgV98U5UjoXPfxlgFpkMpboR8XRsRYnE1YO=w1284-h722-no
front is supported via paracord (it's slightly slanted so that it lays flat with a little body weight)
TI-bWIuL5kYdeG0ZkXCClA59cNMxK07R54X-Dp1_k40SK50hyTUmDcE-eAKBJhjZSuw2zNqLuKRKaxKOk3sgipIFHbWV_pbWmuB0uBn8_5glcnGCJpEQitwaHiWivPltH728s0OF3AfLIfMWMOveDuBdYDWh9JWsN9aw1wSfm-IQds_w7P-iCkR4wvO7k17BQ3Oa8plO7WY_NI2mjGC-IMAyxI9Jidbx_Pf-EZwmzoZuNR7Cb8iSCbKW776NYpzOxfPGsMrDfHF-YLlrWMd3EWTpq1BoPJQ3IT-JLPxjbAPYI_QUl972Z4n3xLx-HeZf-D0dUYBXerxwL-H4TJOAJ44IJpIfaCbBuSaxE-xUgfnjOnU9mqxb3hoVPGA-94v5Juz1a3VWl_6Vxj82ceMM1JCQcfVc77KV6XZP0MQaNPu92i1L9TYuugtyEobZzFp_3D-OOK6x84CEGkVV2oD-AUhmUIiY_PXmouYMSS1Q6gD3M5ahf4zyGlV8R36PGsctl8BihVrcdBhFf1OJZMnSQjzcM4A8s1BxsgLFMcgrff5X=w1284-h722-no
can access baskets from the front and back
TdIhR5d32ntQ04WXT_kFMIxtq-bjwFiFWZAuTrMwbm3qSVgIPgtAk17x8w0cNppVkH1_OWhw4vrcrIAtMIijODiRztQrWHQWhuzClmliADA3zaZIAlybMnRJQZ5J2D4NwHhIPHHO3WLKucTFaGYoJ_5_kUCiWJKnNfc6KbBoGus-5wNkbgoQj95-heO70sqf7CeMIPJnAQkADZi13CNzO1d6nxeIOw7Z4IWESMiI7ozImmMc79uPnt2e_G1onVh5Y8toL_KP5Lqs1nNYNNOw-awo7nBbXIsih9qq270Ltx6wFNVzXHXxD2y6t0O33hoijrCl3p35JBMZCeTDmWoahu3IbD9hHyvFyR2ovuWsG_jQiDDghxtXGNrKw1op3B0OjwP2yXcNIy0dK5niXO1cvVANT5YuJI0xTBDBvKPwjdVnkCaNJbq0rfNfnWv-UyoYVVcNeDg10w3E9ibFzr_RvUxHzKLGym1t3_7o5CZyIkDkaSKGMtCZpN9cySLaLnYRZ4Ws0gIA0KBwWUbh7FJ77mLLOtagQjoqLWKTIXK_eFJk=w1284-h722-no
also, it's all modular and can be used like legos.
I use this set up while camping during the day and then inside to sleep
Qfu-Y0RJFlz9tTFB_mUBQA9nPJZsmOAlKvy06pucnbI4iDmJI9K91ot2vBmACMTC9h265tYJ-6fMBGe2tUP-bCx1LzkQIJH9QCgK4xmCHmWsUj6_xnJNfh34WYQX188jNBjJLmaap89a6hEPppU0JJGCY4zFrXAUZ2IeLotgUNLBrksiU_pRS333xD8tZIKSsDcBGLYtJieKvNfCWGmS2yaxHFWfCCY6J_cFENoY2eEU5ygoacasCOkdedOmKV2_2NLuu2IT8RktyfrGfKglaLFeD7DABlkoqluEPJl5GZitXypj3YEGz2721flAyubClGrJWiDMTLXzHGHDJ08vWCi9GZwI2SDUWhjK-1BCKV99J9RJYO08D1o_bXi9upCp6HgijRLN6EfHu36hQ56iKwZxu-khUFFOfpALPaO3LmmLpe6Mjk9J-nyinEu7UtcdTqH_5GSmqy8BzDmQcc4R7Je7O7Eyz-AY3gIYsRb2s7e2tc38R_cJuYg7qVqsEjZilFdiHWJYMqzh8dawUug1MDKhgD-u88Y9Ov-LEkHLUUYX=w1284-h722-no
bonus:
I also sewed curtains for privacy during car camping.
6fxASRpKRQRSSH5RvnhsBeEBsFig0Hvg2W5Djv9EAenlNZpBrIDDwF6fWopz5vUwVjD0uQJhwBC49xvZBkNngTrPx8H01u4jzd3PqP1PyCWvA1OfJX_xfpACMOPKOSzmmMMoe50Ht9xGN5c0jzGUEQnkbqdn4-aXFoUDVsSlnSUIRNZwep1vTWgH0dArEjrPNZQmbvhx4wInGVs5m_N6_R09tl6P2v-nDTa0XyGvOiQc7epNw2FA5RkKj4pe0enVd8DJhz30VZgZLCtEFq70OT_3KqpHHzWk_YhE5GLRLS_2KIJrwrEAdFXSQ1wKGNrCsnOixlM5zAwlvaVa6__bZCwTNVXipNM7faWYdr00bhvoR1lk3Wrdawdm7RKnyblddHAb9iTbGd-ixXC_n9VAYqb2Jl7wXTtWpe9r031xesZsr45p8oil2qlKB2Tigp4Pe-40MrlhqaHxHcjJD70VT_LCpblADTvta2g-zeFDgdFkvR4Hsoy2x7dyc8EdjmR7MDT-mfc3bG3JoPESc7a0EECFzjNtGUySBqDXBMAkb0nK=w1284-h722-no
comments welcome!
Joseph McCormack
