Full Size Dodge Thread
Area52
I Looked at a 2016 Power Wagon yesterday.
We plan on buying early next year, optioned with a 220 alternator, trailer brake control and popular equipment group.
Extra tow capacity to pull my crawler or Jeep, and medium size RV trailer are the primary reasons, but I also want the factory lockers and 4:10 gearing.
No interest in a diesel.
Jim
jcodyj14
Just bought a 05 power wagon. Low miles clean truck, now I have lots of work to do to it!
12valve, that is crazy about your old truck. Makes me paranoid. I have -8an braided feed lines, but just regular rubber return. A few years back I had a belt driven fuel pump blow out the push-lok feed hose and cover the whole engine bay in the diesel/WMO mix I was running. It smoldered for a bit, but didn't catch fire.
Regcabguy
Oil eater.
Jim
Agreed. if you don't carry a camper or tow heavy they don't make sense.
Thanks!
They are Conti MPT81 335/80R20. I forget the ply but each is rated for 6,700 lbs and run smooth and quiet. No roar like the old 38" XMLs I had. Great tire for anyone looking for something larger.
MPG, torque, time to rebuild is nice with a diesel....
Though I hear its not the case anymore with the new emission strangled diesels and just from the internet stories would stay way clear of them too.
STREGA
My new ride. 2015 Ram 3500 regcab dually 4X, Cummins with Aisin Trans. Dealership is swapping out step rails for 5th wheel adapter/hitch.
bloodyWEST
I'm a big fan of the tall/narrow giant tires, Michelin XML and such. Does one know of anything in the 35-38x 11-12 range for a 17" wheel?
Here's a current pic for fun and to contribute to the post
Texan1983
only thing ive ever found is the 37x12.5r17 it's a good size and looks better than a 35x12.5 in my opinion. But I wish there was one that was a 37x11r17
both cooper and goodyear make nice 37x12.5s though.
I run coopers
Regcabguy
Oil eater.
I run coopers
I like the narrower 37" Coops too. Agreed a 37-11.50-17 would be fine. I need the E range though with the camper. The Toyo's are just too wide. Yoko has a nice 37 but once again a D.
Toyo also makes stuff for 17". I'm sure other brands do to. If want MPT XL/XZL, etc type tires you can either go down a size to a 16" or up to a 20". 16" wheels can be iffy on a 2nd gen RAM on the front due to caliper clearance issues.
bloodyWEST
I suppose I just want the xzl's for the ************ factor. I'm running 3rd gen brakes and tie rods so I'm committed to 17" and up.
I'll have to make the decision between 35x12.5 and 37x12.5 when I'm ready to spend $1500....and that's not soon.
Ancientsojourners
