For this application, drums brakes works just as good as disc. The drums more than capable of dealing with the heat that is generated in this application. You keep hammering Toyota for using drums, but their system works and works better than the more expensive system from GM. Of course you would never admit that. You just keep making excuses for the Colorado performance.
See this is the problem with trying to have an honest conversation about cars with brand loyalists...the fan boy syndrome comes out and the argument devolves to petty back-and-forth. As I said earlier, I'm not defending or apologizing for the Colorado's performance, braking or otherwise. I'm not even saying the Colorado is better than the Tacoma or vice vesa..in fact it was you that claimed the Tacoma was better than the Colorado offroad.
All I said was Chevy was trying to innovate while Toyota was producing a new pickup that bears some striking similarities to the Tacoma it has been producing for the last 10 years.
You still think that unibody is not as rigid as a BOF? You keep saying that you need a rigid chassis for work and offroad use and that making a unibody rigid enough would incur too much weight. You just don't get it. A unibody is way more rigid than ANY BOF can ever dream of. I've already explained why and RoyJ also pointed it out, but that concept just flew over your head. If you want a stiff chassis, unibody is the way to go. This will probably fly over you head again though.
I never said unibody wasn't as stiff as BOF, rather I said that current unibody designs have not been made applicable to offroad or work use the same way BOF designs are. I acknowledge frame twist is part of the reason for having a BOF. But most offroad and utility vehicle designs attempt to minimize frame twist in order to preserve the body, keep components in place, and let the suspension do the work. RoyJ actually brought up a lot of these finer points and also explained why the Unimog's flexible frame and design was very different from most other BOF setups.
If you think that Land Rover's integrated-body-on-frame is a unibody, then you don't really know much about chassis and just regurgitating what the marketing department is feeding you. Land Rover's integrated-body-on-frame is a BOF plain and simple. It has a separate frame with a body bolted on to it. That's the very definition of Body-On-Frame (BOF). But you apparently fell for their marketing which makes since you're a spec sheet and marketing type.
I said as much that Land Rover's design wasn't a true unibody design...my only point in bringing that up was to show that car companies have yet to embrace a pure unibody design for true offroad use.
The real reason BOF is better for work/offroad use is because they are FLEXIBLE. Since the body is just mounted on the frame with bolts and rubber bushings, the stresses that body have to handle are less than what the frame has to handle. The big thick frame will take more of the pounding and it can twist and bend more than than the body and not be permanently damaged. Yes, flex will happen no matter what you do, that's why as RoyJ stated, the stiffest type of chassis (a unibody made of carbon fiber) is not suitable for offroad use because it can;t flex without permanent damage.
I think you're looking for a strawman argument here...I never said BOF designs seek to eliminate flex, rather I said they seek to mitigate it...that's why most heavy duty and many of the full-sized pickups have fully boxed frames, and that's why a Land Rover Defender or Toyota Land Cruiser have fully boxed as well. Construction material aside, a more rigid frame, like a fully boxed one, will do a better job of reducing stress experienced by the vehicle's body and components....these are all points that your friend RoyJ brought up.
Notice, I didn't say the boxed frame eliminates twist and flex, I said that it reduces it.
If you really think that a Colorado is more capable offroad than a Tacoma out of the box, then...I don't know what to say. Go buy a Colorado Trailboss and try to follow a stock Tacoma TRD Offroad and see if you can keep up.
And the fan boy syndrome kicks in yet again...
Have you even driven the Colorado extensively or are you just making these claims because of your adherence to the 'Toyota kicks butt no matter what' ideology?
For your own context, I own a 2011 4runner, and love the hell out of it. I think it's very capable vehicle, even in stock form. But that doesn't mean I can't point out issues or flaws, with the vehicle or the brand as a whole.
Besides, my main point in making these comments wasn't to trash-talk the Tacoma. I've readily acknowledged it is a solid performer. Rather it was to discuss Toyota's overall branding and strategy when it comes to making new vehicles...I'd be more than happy to have a civilized discussion with you on that topic, so long as you take a break from making myopic comments.
