KlausVanWinkle
I have a few Quick questions for ya...
One, how did you mount the drawer in the back? Just use the tie down bolts?
Two, How is the drawer working out for you? anything you don't like about it?
Lastly, Can you post up some info on how you installed your ham radio? I'm struggling with placement on mine, and was looking for some inspiration.
Thank you!!
Hey zig. I have a tuffy drawer mounted under the passenger seat. I used industrial strength Velcro to mount a blue sea fuse box to the back of it. And my ham radio body and speaker to the top. It's work d out pretty well. I think it might prevent the seat from sliding the last notch forward or backward. I ran the cat wire to the little tray in front of the shifter and behind the mesh net on the dashboard and again used Velcro to secure my ham radio face plate there. I didn't use that tray anyway. The rubber part of the tray is removable. So you could rivet the faceplate to that if you wanted a more permanent install.
I go into more detail on page 5 or so of this thread. It's worked well. But I need to find a place to mount the handset.
The rear drawer worked well. I realized that it's pretty heavy when loaded up I hurt my back pulling it out last weekend. Then I remembered the drawer separates from the shell. That made things easier. It doesn't have a hold out feature. But you could rivet a little tab to hold it out like the macs tie down box.
I just used a ratchet strap across the top to keep it in place. But the long term plan is to use the tie down rings and straps or j hook bolts along with the logic track to secure it to the factory tie down points. I haven't tested the clearance of this idea yet though.
If that doesn't work, ill it's the bullet and just install from nutserts into the floor.
So
