Looks fantastic Mark!  I really like the corner caps because they do really finish off the trim.  I might have to drive down next Thursday when I'm off early and check this out if you have some time to show it off. :smiley_drive:
Any time Shane, You might be doing a bit of a self guided tour! Sorry I never got back to you ,it's a little busy.
As far as trailers go, it will eventually happen, we build command units for emergency services and some oilfield units. We are moving composites in that direction. They will never be RV priced, and the will never be built like an RV either.
I got the wood out and started replacing cabinet doors and drawer faces. King Starboard is pretty nice stuff, I added about 10 pounds over pine, so about the same as a good hardwood weight wise. And I know for sure there is one very particular lady reading this that really does not like anything to do with wood! I like the look. Should go good with the flooring that can be seen here, I got the Twilight.
http://www.lonsealspecialty.com/show_product/LONZEBRA Topseal
Comparison
Just waiting for the new latches
Just a little more trim, some cushions, full systems test, and mount it up! Not long now.
