Buying & Building a Medium Ambulance into an RV – The FAM-BULANCE
bobrenz
Thanks, Pat. This was a very low priority project, but I could squeeze it in between starting the sprinkler system, and staining the deck. After some more home projects, I can get going on more important projects.
patoz
I understand about the spring projects. In addition to all of the truck projects I just told you about, I still have to put a roof on my house in the next 1.5 months.
Bikersmurf
I don't know about
, but we all have our own private
so we're ahead of most people!
We all seem to be in same boat. Recently had a disc taken out of my neck... Hope you're recovery has gone well.
patoz
What recovery, my problem is getting worse everyday! It's just something I have to live with, but thanks for the well wishes anyway.
rlrenz
At a certain point in your life you reach for little those blue pills------ Aleve!
Or good old naproxyn sodium for those of us who look for cheap generics.
Bikersmurf
Mine has been better, so long as I don't do much, get tired, or stressed... So I can relate to the boat you're in.
rlrenz
I have a low interior cabinet that has been a puzzle to figure out. Too low to really use it for storage, too large to use for trash. I suddenly figured out that it was perfect for a pull-out porta-john. Right now, the door has two sliding plastic panels, and it's hinged on the bottom. I can easily duplicate the door without any plastic sliding panels, and turn the cabinet into a home for a 2.5 gallon porta-john mounted on heavy duty slides (maybe with a drop down stabilizer?). The end result would be a seat height of about 16", and a lot more user-friendly than a 5 gallon bucket (plan-B).
patoz
Bob, that's perfect for doing what we were talking about!
Just looking at the picture, I think I would make the door hinge to the left to get it completely out of the way of the slideout. You could even mount a TP holder on the inside of it so it would be convenient.
rlrenz
My thoughts as well. Letting the door drop down means that the door has to be part of the support system for the sliding platform, but if I hinge it, then it swings out of the way. You're also right on the paper holder - I had completely neglected that in my mental efforts.
Now I just need to track down some heavy duty slides...
rlrenz
Let us move beyond plumbing to radios. The cab radio in the beast works fine parked, or driving through town, but on the highway, the driver can just forgeddaboudit (sp?). The cab's speakers, a pair of mighty 4" wonders, live in the upper front corners of the cab. I replaced them when I bought the vehicle, but even new speakers don't do a lot for the distance between the driver and the speakers multiplied by the noise level at speed.
The radio's rear channel is also connected to the speakers back in the module, and I believe that the radio's primary purpose is to provide music/etc for the patient. If the connecting door between the module and the cab is closed, the ride in back is amazingly quiet (no siren screaming test has been conducted, at least by me).
As part of my overall plan, I intend to install a Sirius-capable radio in the module that will also provide audio for a TV and for a DVD player. Unless I manage to track down a radio with the capabilities that I want at a price that I can justify, I'll have to adapt an off-the-shelf radio. This means that the cab radio won't be connected to the module any more, and that will leave the rear channels on the cab radio available.
I had been considering some sort of headset, except the boys-in-blue may frown on wearing a headset while driving. Then, Pat suggested some sort of a head rest speaker installation, but the Bostrom seats in the cab do not lend themselves to a headrest.
I finally realized that it is very common to see an ambulance with speakers for the 2-way radios installed behind the driver's head so he can hear them. Problem solution? I dug through my collection of 2-way radios, and found a nice inventory of both Motorola and Kenwood 2-way radio speakers. Even though the Kenwoods are rated at 40 watts (at 4 ohms) each, I'm going to dig through Crutchfield (or similar) to see what's available with a decent frequency response (I'm old enough that I have hearing loss, so an audiophile system it totally wasted on me). The 4" Freightliner factory speakers will be my standard of comparison.
The frequency response data for Kenwood and Motorola speakers might be available on-line somewhere, but I'm probably going to base my decision on what they sound like to me.
The plan now is to install 2 speakers behind the driver, and probably 2 more behind the passenger's seat.
tgreening
For your module radio maybe check out some of the stuff they use for pull behind campers. They might fit what you're after.
What's the dimensions on that port-a-potti you posted? I have a space under my sink that might be a good spot for hiding one, if the size is right.
bobrenz
It's a 2.6 gallon unit -- Dometic #301097402. 12.5" high, 15.25" deep, and 13" wide. $116 at Amazon. Because it will roll out on a fold out platform, my final height will be about 16".
oskarf150
