Tom, why didn't you just remove all of the scene and warning lights instead of taping them off? There are only four screws holding each one on.
I see you also removed the tail lights. Are you planning on painting the diamond deck also?
I figured they'd end up like the tail lights. They come off easy enough but the plugs are captive in the mounts, so it's either let them dangle or cut off all the plugs and have to splice them back in. I wasn't really keen on the splicing or the dangling so opted for the taping.
Yep the diamond plate will end up black. The base color is going to be a desert sand-ish color, which got me to thinking. I'm wondering if I'm going to end up with some shading because I'm painting over white, and that big fat stripe is red.
Beyond that I dont really have a "design". Artistically challenged doesn't even begin to cover it, which is why I'm starting with the tried and true base color / black out the bottom design.
I'm all ears for ideas.![]()
It looks like you had a light bar mounted on horns from the module. Were they through bolted or into tapped holes?
Tapped.
Doubt I'll pull the lights. They're already taped off, and there's 15 of the buggers.
Tapped.
And if you pull them, there will be a strong chance that many of the existing screw threads will be stripped, and you'll have the fun of repairing them. Whelen's instructions say to use a #10 sheet metal screw to install them, but builders more often used self-tapping 10-32 machine screws, and they don't have a lot of thread holding them in. I've tried retapping them with a 10-32 tap and using a regular 10-32 machine screw, but the original threads are usually a little oversize, so that doesn't work.
Ok, some of you guys aren't exactly motivating me to pull them!
