RDC76
Very nice! Is the bottom interior of the pocket threaded to accept a shackle pin? I can't tell how the ProLink is held into the pocket?
Cheers
Thank you as well! And yes the bottom hole is threaded to accept a standard 3/4 shackle pin. The bumper comes with two nice American made alloy pins for each pocket. You can also put a shackle in through just the top hole and have a lot of left to right movement for side pulls. Or double up the shackles and jack up the front of the truck with a Highlift jack. The shackle pin pockets give lots of recovery options and are perfect for times you just need a strap. and don't protrude out the front of the vehicle when not being used. Just keep the threads coated with anti seize to prevent corrosion.
