UNICAT TC52 Comfort
avimeyers
Built in Germany by UNICAT, the world's premier builder of expedition-grade vehicles. This vehicle has been used primarily as a compny demonstrator and show vehicle. It has 53K miles, is loaded, in excellent condition, and ready for some serious adventure travel. A rare opportunity for the individual who appreciates and demands the very best. $450K OBO.
UNICATs in Arizona 078.jpg36AM1 cab pass side.jpg35AM1 cab rearward.jpgElectric Panel.jpg34AM1 R inside body.jpg33AM1 settee.jpg28AM1 bath.jpg21AM1 toilet IMG_5588.jpg
Cab
 Upgraded cab - leather & wood trim, additional insulation
 SS fire extinguisher at floor on left side of driver seat
 Seats - adjustable air suspension front
 Cab rear suspension air bag type
 Power windows & doors w/remote control
 Full gauges & instrumentation
 Cobra CB radio
 Alpine CDA-9857 AM FM XM CD Ipod stereo system
 GPS – Garmin 7500 w/rear view camera and weather fax
Chassis
 International 7400 4x4 (custom ordered off-road fire fighting truck chassis)
 Extended cab - Overall length – 372”, width – 98”, height – 144”
 GVWR – 33,000 lb, GCVWR - 80,000 lb
 Wheelbase – 213” (5410 mm), cab-to-axle – 112”, axle-to-frame – 75”
 DT570 50-state, 310 hp, 950 lb-ft torque @ 1200 rpm, #2 bell housing - will burn any grade of diesel
 Chassis batteries – 2 X 210 ah AGM marine
 Supplemental alternator – 90a with I-U charging regulator for body
 Engine block heater – Phillips 120v/1250w, located below driver’s door
 Air compressor – Bendix TU-FLO 550, 13.2 cf quick connects front and rear
 Allison 3000 RDS P close ratio, 6-speed w/overdrive
 Transfer case – Meritor T-4210, 2-speed, 10,000 lb w/provision for PTO
 All wheel drive, on demand
 Front axle - Meritor MX-12-120 single reduction, 12,000 lb
 Rear axle - Meritor RS-21-145 single reduction, wide track, 21,000 lb w/driver controlled main locking differential, 200 series wheel ends and ABS gear ratio: 5.13
 Air brake ABS – Bendix antilock brake system, 4-channel
 Front brakes – air cam, S-cam, 16.5” X 5.0” inc 20 sq in MGM long stroke brake chambers
 Rear brakes – air cam 16.5” X 7.0” inc MGM TR3030 long stroke brake chamber and HD spring actuated parking brake
 Exhaust brake – D Logic, electronically activated
 Air dryer – Bendix AD-IP with heater
 Military aluminum split rims with run flat capability
 Michellin XZL 395/R20
 Fuel tanks – 2 X 100 gal w/ 9mm skid plates (approximately 1,500 mi highway range)
 Racor fuel prefilters w/ water separators/heaters
 SS roof rack – generator cooling system, storage, work lights, and 4 X Hella 2100 HID lights
 SS wire mesh head lights brush & stone guards
 Winches – hydraulic 15,000 lb front & rear w/15 gal reservoir and PTO pump
 Rear bumper - SS fold-down under-ride protection
 Front bumper 2”X2” receiver for motorcycle carrier
 Water fording - all breather tubes raised to minimum 5’, positive pressure in generator compartment, sealed storage compartments
 Generator – 8kw Fischer Panda
 Spare - rear mounted w/manual hoist
 Rear rack storage – manual hoist
 Body Unit
Frame assembly
 3-point kinematic attachment with main and flex mounts for stress-free body coupling to the torsion elastic chassis frame
Body unit construction
 Body dimensions – length 205” X width 98” X height 83”
 Self-supporting UNICAT sandwich panels of fiberglass composite
 Panel connections made by adhesive bond to custom extrusions eliminates metallic heat conduction paths
 Matched thermal coefficients of expansion prevent distortion with changes in temperature
 Wall thickness 2.36" ( 60 mm ) with polyurethane foam insulation, 0.12" ( 3 mm ) FRP outer surface, 0.08" ( 2 mm ) FRP inner surface
 Insulation rating 0.078 btu/ft h degF ( 0.44 W/sqm K )
 Floor panel with integrated welded steel frame and surfaces of fiberglass reinforced polyester
 Teak flooring
Access to body
 Cab-to-body passage – 23” X 32” w/solid & soft panels
 Highly flexible waterproof bellows coupling
 Access to body – hydraulic stairs, 3 control locations
Entrance door and storage compartment doors
 UNICAT - entrance door and storage doors constructed of fiberglass composite panels and frames, 3-point stainless steel safety locks, mosquito net at entry door
 Thickness of doors 2.36" ( 60 mm )
 UNICAT double seals with heavy duty lock
 Stainless steel hinges throughout
 Additional retractable stainless steel bolts at middle, top and bottom of doors
 Safety cylinder locks all keyed alike
Windows
 Burglar-proof, scratchproof, double paned, thermally insulated
 Shutters and mosquito nets
Interior Lay Out
Inner dimensions of the cabin
 Length 200" ( 5080 mm )
 Width 92.9" ( 2360 mm )
 Height 76.8" ( 1950 mm )
Seating area
 Seating area for 2 - 4 people with adjustable swiveling table on pedestal in the front of the cabin
 Seating unit converts to double bed
Bed
 Queen-size bed with suspension, ventilation and comfortable mattress in the rear on pedestal
 Size: 60" x 80" ( 1524 mm x 2032 mm )
Sanitary room
 Sealed fiberglass door to isolate bathroom from living area
 SeaLand ceramic toilet system
 Bath sink – SS w/extra faucet for filtered water, soap dish, towel hooks
 Shower – full size w/adjustable height head, 2X soap/shampoo dishes, SS overhead drying bar
 Medicine cabinet and storage under sink
Kitchen
 Countertop with integrated SS sink
 Collapsible counter top leaf to left of oven/range
 Single handle faucet for warm and cold water, separate faucet for filtered water
 SS soap dispenser, soap dish, towel hooks
 Force10 LPG 3-flame range/oven
 Sanyo 1.2 cubic foot SS microwave oven
 Kitchen cabinets with locking drawers on ball bearings
 Built-in drawer organizers
 Overhead cupboards
 Refrigeration – 2 X 113 liter Kissman w/small freezers, 45 qt freezer and in under bed storage compartment
Storage
 Inside storage space in the seating area, kitchen and over bed
 Wardrobe for hanging clothes, pull-out storage boxes
 Large outside storage compartment under the bed pedestal
 Exterior storage - 2 X SS 24” X 24” X 24” 1 X SS 24” X 24” X 48” tool/utility boxes w/drawers and dividers, cab roof rack storage 18” X 30” X 54”, rear rack storage 46” X 44” X 23”
Workmanship
 All furniture is built to the highest cabinet making standard made of wood core plywood using heavy duty locks and hinges
Lay out
 Upholstery made of ALCANTARA
 Walls and ceiling are painted with multiple coats
Technical equipment
Electrical equipment
 Solar panels – 3 X 123w Sharp
 Control panel for power management and monitoring of liquid levels
 Battery main switch, safety cut-out, residual current breaker
 DC power supplied by (4) AGM batteries bank, automatic regulated alternator and AC automatic I-U charger with cell temperature sensing for shore power hook-up
 Battery capacity: 12V 840Ah
 Shore charge rate: 14V 120A
 Inverter – Outback 12V / 115V, max output 3.0 kW
 Power plugs for 12V DC and 115V AC
Audio-visual system
 Alpine CDA-9857, CD changer, AM FM, XM sat radio, Ipod
 Sharp 21” LCD HDTV/DVD players at bed and dining area
 Brackets and wiring for outside speakers
Lighting
 Low voltage LED ceiling lights over the table, kitchen, bed and shower
 Lights for outside storage compartment
 Reading lights in bed and seating area
Water supply
 112 gallons ( 425 liters ) freeze-proof drinking water tanks
 8 gallons ( 22 liters ) hot water heat-exchanger
 15 gallons ( 60 liters ) waste water tank
 25 gallons (100 liters) gray water tank
 All plumbing is insulated to prevent freezing
 Outside shower at rear luggage compartment
 Water filtration system at both sinks
LPG supply
 2 x 30 lb. cylinders in sealed compartment
 Quick connect for barbecue at rear luggage compartment
Heating, ventilation and A/C systems
 Webasto diesel powered warm water central heating ( 5 kW )
 Redundant 120v hot water boiler
 Radiant heaters at shower, dining area, and coil under bed
 Anti-frost system
 2 X 13,500 BTU Penguin A/C roof units
 Maxxfan units above sink and in bath
Alarm system and emergency equipment
 Fire, smoke and carbon monoxide detector/alarm
 Mag-lite flashlight/charger at door
 SS fire extinguisher at door
mhiscox
Exp. Leader Emeritus
Whomever buys this truck is going to be so "blessed" by the karma of the previous owners!
Hmmm, I could make use of that about now. ;)
I agree that it specs out to be a wonderful rig. Makes me sad to have frittered away my money on my XV-JP.
DzlToy
Does anyone know how the custom drawer organisers are made? CNC cut for each cup and plate from thick foam?
Any comparable products on the market other than cube pluck foam?
Victorian
In my days at Unicat we did all of that by hand, for each piece...
mk216v
Der Chef der Fahrzeuge
WOW, what a iconic rig.
Ok M.H., you got me;
"Workmanship
 All furniture is built to the highest cabinet making standard made of wood core plywood using heavy duty locks and hinges" ;)
zhukoveli
