2006 DC Tundra. DD meets ongoing tinkering.
wrenchMonkey_
When do we start the bumper... looks like it's got a cleft palate like that
She don't look that bad from the front!
Excited about this ...
Little sad that I went and simply bought a bumper. Like I took the easy way out.
I got a feeling I will learn a lot from this.
GC
John, by the time I am done this build I'll probably be wishing I just bought one, hahaha!
I do enjoy building it and spending time in the garage. As far as costs, I am into it for $70, which was the 7x2 C Channel I got today. However, that was 10ft and I used 3ft, so really about $25 bucks is all I have spent. The 3/16 plate, bolts, ect I had lying around. I've been using electricity its going out of style. Between the plasma, welder and heater, $$$$$. Atleast +$30 this month for sure. I just could not justify spending the $1000+ USD that most companies want for a bumper. Also, I didn't want a plate bumper, so that left my less options. I do have mad respect for the companies the design and prototype the stuff. Thats the hard part. Once its designed, CNC Plasmaing the parts out and welding it up on a jig is easy.
I am learn something knew every time I fab something. From my rear bumper to my sliders and now this bumper. Seeing as how I' got my first welder in Feb of 2016, I am excited to see what the next few years should bring as my skills and tools increase.
Todays lessons.... buy a mag drill. Some of my mounting holes came up a bit angled and crooked, leaving some tight tolerances. Drilling it with my 1/2 corded drill was a PITA and I wanted to off my self. Also, drilling blind through the upright and trying to hit my 1/4 sleeve was a bit of a PITA. I am happy with 3 out of 4 of my holes and I fixed my mistake on my the one. Either way, it will hold.
Lesson two. I knew this was going to be an issue after dealing with my rear bumper build. Because my uprights sit over top of the frame, and its almost impossible to put this thing on straight and just slide it back into place, it take a bit of rummer martingale to get the bumper to slide over the frame rails and into position. If I left the fit sloppy, I'd have alot of play and leave all the holding power to the bolts. If I made it any tigther than I did, once I welded it up and got it on, I'd never get it off. I see why the OEM style and alot of aftermarket is a flat vertical plate that you can line up with your bumper and have the bolts running inline/parallel with the frame instead of my design, where they are perpendicular. That being said, with my design and what I wanted, parallel was not doable.
Anyways, on with the pictures!
Picked up some steel from the metal yard. Went with 7x2 channel. .210 thick. 9.10lbs per ft. Used as my winch mounting plate. 6x2 would of worked, but all my yard had is strucutural where the edges are tapered and no straight walled stuff. Anyways, $70 and I've got material for 3 or 4 more.
Once I got it cut to length I drilled the holes in the 10x4.5 pattern for the winch.
After honestly an hour of sitting in front of the truck, checking all the angles, measurements ect, making sure everything was flushed and square, I finally threw some tacks on it and after it cooled pulled it off. Hoping that it did not warp at all and that I could still get it to slide on, I gave it a test fit, and it still slid on. Happy days!
and here is where I left off tonight. Got all 4 frame/upright mounting holes drilled. Went with a UNF 1/2x5in Gr 8.8 bolt for mounting. Two per side. As mentioned above, the holes could of been better, but whatever. Honestly, I might have just gone with one big M16 or 3/4 bolt instead of two, but live and learn.
Tomorrow I'll drill the bottom two mounting holes that go into the bottom of the frame where the factory tow points were, then I'll weld the rest of the winch plate up. Might start bending some tube tomorrow too.
rickashay
Love where the design is going. Similar idea to what I had sketched up for Doug with the open area for the winch... or at least what I can see of your build now! Looks deadly.
GasCan
I hear ya! After my rear bumper I think i was done with all the designing, cutting, second guessing, redoing,.....
But its all great in the end.
GC
wrenchMonkey_
So, I've been making progress pretty much daily.
Worked late last night to get the top bar sorted out and welded up.
I am happy with how it turned out.
With the top bar tacked on I pulled the bumper off the truck and welded it all up on the bench.
Just threw this on there to mock up the angle and try and sort out how I want to do my skid plate. However, oddly enough the 30Wx20L size that the foam board came in is almost perfect. It will be mounted on small tabs and have about a 1 in gap on the top and sides.
I am thinking I'll cut 3 small 2in long sections of 2in DOM up, cap them and drill and tap two holes inside it. They will get welded under the winch plate and give the front/fairlead skid plate something to mount too. I'll try and bend it on my bench using alot of heat and some wood and a big hammer, but, I may end up cutting it and taking to to a shop with a break to bend for me. Cant be too much $$ if I have it cut and marked and tell them what angle I want.
After all that, I wanted to do something easy. So I installed the Blue Sea 6006 battery switch and mocked up a contractor bracket.
wrenchMonkey_
Nice work! What are you going to do for "wings" on the bumper?
Been toying around a few ideas of what I want to do. I am defiantly going to close it off. Probably have it follow the same angle as the top tube and then tie it into the bottom of the upright. Not the very bottom, probably a few inches up. Notching and bending the angles will be a tough one. I am thinking of going with 1.5 tho, which I'll have to do at a friends house. I think it will look better.
Once its closed off, I am thinking of possibly sheeting it closed and putting in some 2 or 3 in lights. Something like a Baja Squadron Pro. Having two low ground wide spread driving lights in the lower wings and then some sort of spot uptop.
On the top, I am going to do a stinger bar, but I am torn about going with my 22in LED Bar I have or getting some of the 9in round CREE LED (ARB Intensity style) and running two of those. The reviews have been great.
wrenchMonkey_
bumper looks great. What plasma are you using to cut that plate?
Thanks!
Currently I have a Hypertherm Powermax 45. Its a great unit. The 20 ft leads are great and the unit is easily adjustable depending on what your cutting, ie sheet metal, expanded steel, gouging ect. Also, the built in air regulator is nice.
I had a Miller 375 Xtreme Plasma before and while it was a great unit, I enjoy the extra 15 amps on the top end the Powermax has.
wrenchMonkey_
Been slacking on posting updates but lots has been happening.
First things first, got the wings on the bumper. Getting the angle, the cuts, and then getting it symmetrical was a half day job that I don't want to do it again. I see why alot of companies just do a straight bar, no bends, on a 45 from the end of the top bar to the bottom of the uprights. Anyways, I am very happy with how it turned out.
Notched out the winch plate to increase clearance between the cable and to let me get my hawse as low as possible.
Replaced my AC Condenser after the drill bit incident, which, also let me clean up my radiator as it was pretty caked with dust and other crap. Should help the airflow and help lower temps a wee bit.
Removed the power steering cooler. I'll be installing a finned aluminum dual loop cooler if the temps become an issue. Had to remove it because I did not have enough clearance between the winch plate and the radiator for the stock hard lines. Ran a new return line from the rack to the reservoir.
Got the power and ground lines ran for the winch. Ran it off the AUX battery and tucked it in the gap above the radiator. Ran it through some 1/2 cable loom to help keep the temps down on the cable. Its 90c insulation and Ive checked then temps with my IR gun. I don't see it being an issue unless I am running the winch super hard, I'll see what happens after a few test pulls. Its not touching anywhere which was the result of 30 minutes of routing cables and zip ties and sore fingers.
and picked up some new hardware for the bumper and winch mounting. Top to bottom, Gr 10.9 M12x1.25x40mm bolts for the tow hook/lower plate mounts. Gr 10.9 M12x1.25x120mm for the through bolts on the uprights. Gr 5 3/8x16 for mounting the winch.
Need to pick up some more Deplhi/Deustch pins for wiring in my Warn remote and then I'll finish the in-cab install.
Then I'll cut and work on the skid plate.
wrenchMonkey_
Looks good, fab work is always more work than u think
So true Tyler, so true.
Finished off the in-cab winch switch wiring this afternoon. Gotta pick up some HDPE or something similar to make a bezel to fill the gap and make a switch mount in the re-purposed change cubby.
AaronK
Nice! I'm thinking about doing that too. Running a cable from my bumper across my hood and through the window is tiresome
Sent from my OnePlus One using Tapatalk.
spazstic
Lives for the weekend
Just read through your thread. Thanks for the info for the brake proportioning valve, it'll save me some head scratching tomorrow.
Truck looks good, you've done a lot over the past year. I also like the bumper, it looks like it'll end up being similar to the one I built.
wrenchMonkey_
Thanks. Any questions about the valve feel free to ask, but its pretty straight forward. If you are doing the lines your self, make sure you have a good flaring tool.
Bumper turned out great. I'll have a picture up this afternoon with the skid on the truck. Total weight is 90 lbs for the bumper and skid and 40 for the winch. When I cut my fenders for 35s, I had no bumper on, now, my clearance is a bit less haha with all the weight. I may have to do a bit more trimming.
Hah ya, its been a pretty busy few months, things escalated quickly. However the bumper, sliders, winch and dual battery are things I've wanted for a while. Its nice to have and I cant wait to get out and give em a try and dent/scratch them.
DanoWall
