El Camaleon Azul. an '08 V8 4x4 T4R built to go.....
zidaro
Snowing in the Sierras!
Mobbed around on the local 2tracks getting the Freshies!
zidaro
Weekend report
Shredded windbuff perfection Mammoth Mtn. on Thurs.
Left Mammoth Fri am, snowed 3"
Drove thru Death Valley in the wind. This is looking into Panamint Valley
Hike to a waterfall (Darwin Falls)
Stayed at furnace creek ranch
Ran a marathon across Titus canyon road 26.4mi with 165 other peeps
Wife got 2nd in her age group. 89th finisher 5:13time.
I was 64th. 4:49hrs
Daughter was race volunteer and passed out all the medals to every finisher, and a beer to her Dad.
Red Pass looking into Titus, and below looking back towards Beatty
Did killers in the dunes with Daughter
Drove out north on dirt thru crankshaft and eureka
Ate Thai in bishop for dinner Sunday night
Life rough. Great weekend. Im sore
zidaro
Specs on the wheels/tire combo I'm currently running.
Guess i forgot to add this anywhere :)
Wheels - spec. off Racelines site.
RT233 AL Monster Cast Beadlocks
RT233-79560-32-AL
Weight:44.00
17x9.5 / 6x5.5 / -32 / 4.00 / 4.250
cast isn't my first choice in alum. wheels, but i could not $$ front for the forged this time.
2800#rating
i weighed them on my scale with the alum. ring and all hardware, came out to 37.9# every time.
and the Cooper Discoverer ATP in 295/70R17
great traction in the ice/snow so far.
I did slash a sidewall nicely in Death Valley riverbed. But i was rallying a bit fast. :police:
Beadlock install- my thoughts.
I always pound a grove/notch in the inner bead retention hump to give the tire bead something extra to grab onto before it slips over the hump. Makes a big difference keeping the inner bead from popping when your aired down. ~1.5" apart all the way around. Learned it from a baja legend.
spit on your inner tire bead little, and push the front of the rim thru the inside wall.
now set it on a 5gal. bucket face up.
Carefully line up your tire bead centered on the bead ring of the wheel.
Lay the lock ring over the tire, again centering it on the wheel and bolt holes visually.
I mark with nail polish the ring and wheel at 15* increments using 2 colors so i can remember my bolt tightening sequences.
i use copper anti-seize on all bolts.
insert 4 bolts at 15* each and finger tighten on opposites. insert 8 more between those bolts and finger tighten
Now, criss-crossing back and forth and at 30min. on your clock of bolts, start tightening to 5#, then 10# all bolts. Once your hand tight- Use a torque wrench!!!!
Like the proper lug nut sequence, only WAY more bolts. Idea is to never over tighten one section and cause the lock ring to start slipping to one side. this will cause wheel imbalance.
once at 10#, i thread rest of bolts in and tighten same way.
Final sequence torque to 15#.
recheck your torques on every bolt till they are all at 15-17'#
Takes forever. but its done correctly and may even balance well if you did it right.
How i balanced my wheels.
The ceramic beads seem to do a great job. Not always perfect balance but usually pretty good and the best part is it self corrects with tire plugs, chunking, ice/dirt in your wheels, tire rotation when aired down(this one shouldn't happen if your deadlocks are working), standard tire wear. No rebalance needed.
Ive never tried them, till now, on a more street driven rig. They work amazing on my 37" Pitbulls/beadlocks that i run on my crawler, but it sees way more dirt and rocks than pavement.
once you pour in the beads, thru the backside of the rim. pull your valve core, wet the rear bead a small bit with slightly soapy water, and fill the tire till the rear bead pops on, pressure down to ~30# immediately. 88#10oz total/each
this
to this
:rockon:
macgyver_ga
Snowing a little in Cali this week. Started last night, forecast is for a solid week
You still alive out there? Just saw an article on the weather report for mammoth, Holy smokes that's a lot of snow! We just got about 2-3" of snow plus some ice here north of Atlanta and it basically shut everything down. Went out in the Tundra and had some fun yesterday, also took my wife's '12 LE 4R (same as your wife's) out on Friday night a few hours after it started and had some fun.
seanpistol
When I lived there, starting on new years eve in 2005 it snowed 9' in two days. We had tunnels to our place in the ghetto. There were cars on the road that weren't seen again until the spring and they had the windows smashed when they thawed out from the weight of all the snow.
zidaro
I remember that storm season! It hurt. I was a MMSA Host that year, snowboard or skied everyday. Shoveled and drank all night
We've been getting POUNDED this week and its not supposed to let up till Saturday. 8 more feet in town this week they predict. Gotten about 4 feet at the house since start of storm, snow mixing with rain at this elev.
Mtn. is buried.
Wonder if we knew each other? I lived with 8 roomies in the Aframe right behind GoatBar. UGLY!! :drool:
You still got over this way?
zidaro
Yep. Im here! Its an amazing weather event so far, 2017!
Lots of work, but always great to see the Sierras get water, and even more amazing to see how Mother Nature can serve up a beast- and how us humans deal ;)
Weather Dudes are calling this a Record Event and they haven't even seen the end in sight. Supposed to get a 1 day break on Sat. the 14th.
We've gotten atleast 4foot more since i took that pic. House is buried and now a full time job to keep windows and doors clear, my deck is a lost cause. Roof is getting sketch and has 6' of VERY dense snow on it as we had mixed rain/snow for a couple days. Now were back to low temps and lighter snow. Last night it switched from freezing rain to snow, dropped 8" by 6am.
I live about 5min. from the lifts of Mammoth Mtn. at 8005', so we get the heavy weather, but the Mtn. gets about twice what we see on an average storm cycle.
seanpistol
Mtn. is buried.
I was a liftie that year, worst job I've ever had. And I bussed tables at Grumpys. I lived in employee housing on Manzantina, or maybe I lived on Manzanita in a condo the second time, is Mono a street? Can't remember... I tuned skis at night at Footloose the second season and lived with friends, skied everyday, and had a fake ID so I was at Lakanuki 5 nights a week, hahah. That was a good time. I still get out there once in a while. I used to come to ski the park late spring when it was huge and Utah resorts closed down early due to their forest service lease. These days I ski twice a year at most and ride my snowmobile every day that I can. I still have some friends in Mammoth and my Mom lives in Bishop now.
zidaro
Ha, ****! I was exhausted last night and read that year ALL wrong! thought you wrote '95. I was here in '05 for certain. I own TONIK, a retail clothing shop, we were in the Village in 05, really till '12. now we are by VONS on OLD Mammoth Rd.
I also work as a Full-time Paramedic for Mono Co. Fire Rescue in Mammoth.
Anyways, I'm sure we crossed paths a few times- spent much time in Footloose and None in Grumpys :) Good friends own Laka!
Hit me up next time your headed this way, go wheeling, shred the mtn., or have a drink. All good.
Aaron
zidaro
Lil midstorm reprieve out wheeling the slush trails at lower latitudes from mammoth (Long Valley :) ) Gorgeous sunset to follow.
Henrybrowne
