FOUND Vans For Sale!
Jsweezy
2001 E350 7.3l Bus 300k miles - 6k dollars, no affiliation.
http://westernbus.com/bus-inventory/2001-fordgirardin-stock-16ub049/
Jsweezy
^ sorry for the massive photo... I tried to use the small one but couldnt figure it out.
I also found this today. Smaller Box truck, v8 5.4l, 5 speed, full float rear axle with Traction-Lok. Literally just throw a 4wd conversion at it and you have a camper that would be more than capable.
http://www.commercialtrucktrader.com/listing/2009-Ford-E350--120553711
Edit - Or pull that box off, throw a cab back 42" shell behind it and fab up a flat bed for the rear. I need more money...
jydog
You also would't have to worry about cutting the fuel tank it's mounted in the rear.
Jsweezy
Yep, no fuel tank cutting or relocation and the 5r110w doesn't need to be dropped either. It has the same wheel base 138" as the passenger vans. It's literally the easiest diy project for someone looking for something similar to an ambulance. I could have MGs kit mounted and driving away in a day.
Oh and it doesn't appear to have RSC either.
DanoWall
