Blender, My LX450/FZJ80 + FJ45esk + GM + Land Rover crazy concoction
Here's one I made for a '06 4Runner. The stock one is on the left, modified on right.
This one is totally custom, but in the spirit of the Ford mount. The rubber there is for mock up only. I went with custom made isolators for final install.
These are on a '87 4Runner (Superrunner) with a 4.0L V6, using an Afco radiator.
This is the upper mount for the Superrunner.
Metcalf
Nothing amazing, but I did do something tonight. Even those small bites add up....
I finally got the right clutch and fan that will work together.
Clutch- Hayden 2986
Fan- Derale 17917
I did have to drill the mounting holes in the fan out to match the M10-1.5 hardware ( and I need to get some shorter hardware )
Overall the package fits very nice. It is only 3" thick total. That is more compact than most electric fans honestly. There needs to be a little space for things to move around as far as the shroud and clutch, but overall it is very compact.
My hope is that this mechanical fan will move more air than even the largest electric fan would with this size radiator. Running a clutch fan sure does make things simple it seems.
I was also able to pull the crossmember out for some more holes. I added two 7/8 holes for winch cable pass through ( with grommets ) on the passenger side. I also added the holes for the lower radiator mounts. I am going to have to make those a bolt in piece so I can R&R the power steering cooler.
Next....radiator mounts.
Metcalf
Those are for power and ground? I think I recall you talking about a midship mounted winch in one of your previous threads, no?
Yup, just power and ground wires. This one is getting a good old Warn 8274 mounted proudly on the front. The mount will be kinda similar to my flat fender with the winch sunken down behind the bumper with the hawse down low behind the face of the bumper. I think it is really hard to beat the performance of the 8274 all around. They just seem to look right on older vehicles with extra frame out front.
I was going to make a mid-mounted winch for my Dodge, but I drive the thing too much to take it out of service for that long.
redthies
Renaissance Redneck
I have an 8274 waiting for me to have spare time to rebuild it. They are great winches. I was going to put it on my CJ7, but not 100% sure the zjeep is going to be around too long. Now if I could find a decent FJ40 for the same cash...
Metcalf
Yup, something about the 8274 is just over-appealing. Maybe it is because they are one of the only winches heavily supported in the aftermarket which you can mod to the moon....
People seem to be really proud of FJ40s, that is for sure. Hunting parts for this build gets a little old, that is why I ended up building so much from scratch.
Honestly, I just keep moving towards building vehicles from complete scratch. I think if you are going to throw away, or have to replace, 80% of the base vehicle it might be the better way to go in the long run. I have been working towards being able to build a complete vehicle of my own design for a few years. That is where I will probably end up.
Metcalf
Only a few little brackets tonight....
The start of the lower radiator mounts. These will bolt into the new crossmember under the grille.
Folding a U-shape that fits inside another U-shape that you folded is harder than I thought it would be....
Nice little crossmember. Looks almost stock.
I drill an oil fill hole in the 8274's. They will leak over time, and it's nice to be able to fill the oil before you get around to replacing the seals.
Metcalf
Thank you, that means a lot coming from a quality builder such as yourself.
Good tip on the 8274. I will add that to the list!
redthies
Renaissance Redneck
Between this one and your flat fender, you've pretty much already done it. The sheet metal would be the hardest part, but I think you could make it fly.
Metcalf
Finally some progress worth posting...
I was able to finish up most of the upper and lower radiator mounts. Since the grille is hard mounted to the frame I attached the lower radiator mounts to the new crossmember I added under the grille. That crossmember also houses the power steering cooler so the radiator mounts needed to bolt on. I decided to do a channel in channel type mount.
The lower mounts use 3 mounting bolts to provide some sideways stability in the long term. There is a secondary mounting nut in the mount for an air flow plate to help force air through the coolers and keep re-circulation down.
The upper mount attaches to the front top edge of the grille and uses the same Jeep XJ mounting pads as the bottom. This makes for easy to find common parts. The radiator is slightly offset to the passenger side so the mount isn't perfectly symmetric. I tried to hide that in the visible parts when the hood is closed. The dimples really stiffened up the panel overall. I am always amazed by that.
One interesting thing with the FJ40 front clip....
There is an opening for airflow on the front of the hood above the grille. I added a few holes on the front to the upper radiator mount. I omitted the outer most holes ( I can add them ) because I am thinking about adding a small 'scoop' to the upper radiator mount. That scoop would capture air from the hood opening and force it though the upper part of the radiator....and keep the fan from sucking hot air from in the engine compartment. Thoughts?
Misc stuff....
new style of weld nuts. I like them. Cheaper. Easier to weld into place. More threads.
Lower radiator mounts out of the chassis.
I have some some more air flow 'ducting' to do in the grille still. I need to make a shroud. I can start on the front bumper now. Need to mount the headlight adjusters and figure out the final depth for those. The hydro assist ram also needs mounting before the winch. I'd also like to start working on the bed....
Metcalf
I had a little bout of airflow OCD....
I made a small scoop to direct the air flowing coming from the hood gap into the radiator. It should also prevent the re-circulation of hot air from under the engine compartment in this area. I also added the outer holes into the upper radiator mount for a little more flow since the scoop didn't get in the way...
94Discovery
top is done now the innersides all these small details makes a perfect truck ,amazing work as always .
Metcalf
Just a little bit of an experiment....
I decided to try something different to stiffen up the upper grille braces. I added a small 1/2" wide flange at 45 degrees to the inside of the triangle shape. That REALLY stiffened up the panel and took out a decent mount of weight too.
These will be hidden under the fender eventually. I will need to add a fender mounting hole near the coil bucket. With a little foam weather stripping that should help keep things from rattling where they overlap onto each other.
Details.....
jordanP13
