I got here as fast as I could - '04 Suburban Z71
tbisaacs
Best $25 I've spent. Dorman replacement radio buttons. Previous owner sharpied all of the worn ones.
Before
After
tbisaacs
Making my way through swapping out all the lights for LEDS.
Tails/brake lights, rear turn signals, reverse lights, plate lights, and puddle lights are done outside.
Had to install an LED specific flasher to avoid hyper flash. I thought I had gotten away from having to use resistors but now my cruise doesn't work. Google tells me that resistors on my tails will fix it.
Everything is swapped inside. It's hard to capture but looks great.
99% sure it is worth the hassle
kojackJKU
Autism Family Travellers!
Are they brighter than the normal bulbs inside? my buddy replaced one of his interior lights with an led and the regular lights are WAY brighter.
tbisaacs
Yes but not obnoxious. Biggest difference is in the row of dome lights.
Martinjmpr
Wiffleball Batter
Hey, what kind of dog barrier is that? I've been looking for one that would fit my 'Burb. When we travel with the dog it would be nice to keep her separated from all the gear (she sits on the folded down right side rear passenger seat so she can have a window to herself.)
tbisaacs
Highland 2004500 Black Universal Pet Barrier https://www.amazon.com/dp/B0002MABGE/ref=cm_sw_r_cp_apip_CP8h8vIeIW2Q1
It's okay... I have behind my folded third row. My plan was to stow my third row seat in the garage when not in use but the barrier isn't tall enough (my burb is missing the flaps behind the rear seat that cover the hole in the floor).
tbisaacs
Well, I guess I'll have to sort out my power situation—because I accidentally bought an ARB50 :D
I just happened to find a used one locally at a price that I couldn't refuse.
My Suburban has an ancient off-brand battery that I've been meaning to replace. I've been doing a lot of research between a dual battery systems, it's pretty straightforward, as the suburban has a spot for an aux battery. However the Goal Zero Yeti 400 + some Renology panels is also very appealing. I like the idea of the Yeti because we could move it to another vehicle, etc.
For now I'm probably just going to get by with a single Optima or Odyssey. I found a helpful thread here on Expo confirming that even with a single AGM battery, I should be fine running the fridge overnight—with the caveat that I should also have a jump pack:
http://forum.expeditionportal.com/t...ge-Please-help-me-set-it-up-so-I-m-good-to-go
chilliwak
You got to love when you acidently buy things. Lets see that fridge out in the bush with some cold suds and a steak or 2 for the campfire. Cheers, Chilli...:)
tbisaacs
Loaded up the fridge and the pup and explored Washington NF-56. With the exception of a few deer, we had the place all to ourselves.
tbisaacs
Also finished tidying up my center stack. Re-faced the radio with new Doorman buttons, replaced the 12v socket with a marine-style dual USB charger.
The biggest improvement was with my Garmin. I picked up a longer mount that allowed me to stick it to the dash and hang it over the radio. Much more usable now that I can reach it.
I also hardwired it using a fuse tap. Instead of plugging and unplugging, it comes on with my key.
I had planned on just cutting the 12v plug-but that didn't work because there is something in the plug that is required for the Garmin to work. So I bought a new Garmin cord, plugged it into a female 12v socket, then wired that to the fuse tap.
tbisaacs
Links and bushings replaced. Immediate improvement!
I made a rookie mistake and took off the front wheel. I realized my foolishness as I was jacking up my LCA to bring it up close enough to get the bolt for the sway bar link on.
While I was in there, I poked, prodded, and wiggled everything and it all seems tight. Including CVs and tie rods.
rayra
Good times. Were there any directions on the front sway bar connectors, about how much to tighten them? The top ends look a little loose on the sway bar ends. Should be a bit more squished, to my eye. But I might be wrong.
Did you put new rubber boots on the tie rod ends?
I don't see any jackstands in the photo, I hope you used some as just the floor jack can have some terrible consequences if it gives out.
I've been pricing new bushings and ball joints, toying with using that work as an excuse to get a hydraulic shop press. But the price on the rockauto complete OEM complete control arm sets is changing my mind.
Looking at your superbright interior lights, really liking them. Just LED replacements, right?
tbisaacs
Good eye. I didn't tighten them until I put the wheel back on and got it back on the ground so the LCA would compress to its resting height.
The instructions suggested tightening until the bushings bulge slightly and then back off 1/4 turn.
Definitely used a jack stand :) Just couldn't see it in the photo.
I didn't replace tie rod boots but they looked new. As did CV joint boots.
Here are the LEDs I have
www.amazon.com/dp/B00HRSTP1S/ref=cm_sw_r_cp_apip_Yav6GzqZfWEGS
The quality is okay. I have other bulbs from superbrighteds.com and they are much better. The kit above only comes in 6000k which claims to be white but it's a little blue.
superbrighteds.com has warm white for all of the interior bulbs except the courtesy lights. If I were to do it over again I'd pay the extra for the color I wanted and quality of their bulbs.
V45W_Proto2.5
