Replaced front sway bushings and end links with the HD version from Britpart made by Meyle:
For the ne difficult bolt others have mentioned, yeah, it's only accessible by a short narrow 18mm socket that is usually going to be non-impact due to smaller barrel. I used two different box wrench shapes to first break it then the 3/8 non-impact socket with 3/8 impact universal joint and extension on an air racket with about 560 ft-lb.
However, if you have the tools to loosen this item, it is mounted in a pivot type connection to stay against it's counterpart. If you just create a 1/4" or so gap, it allows much better access to the upper bolt. No problem rally but the torque to break these three was more than I could get with a 12" long box wrench so I used the air tool and it still took maybe 10 seconds duration to get them moving.
Retigjtening them I went to a 16" long 1/2" rachet followed by the air tool to see if same time would nugget it which it did about 1/16 more turn.
Some of the tools used for reference/planning your own
