tgil
So that black piece stays on the Jeep all of the time?The side-mounted configuration from MORryde is GREAT for carrying a full 10-gallons of water or fuel without loading extra weight on the rear door hinges or taking up space on the roof rack (I've tried many alternatives). I installed my CB antenna quick-mount at the designated access point in the MORryde brackets. Since I change configurations several times a month, I installed four massive rivnuts on each side that enable me to mount or remove the bracket in 10 seconds with a drill and socket (NASCAR pit-crew style). I also cut one side of the brackets so I can use it to dispense 5-gallons of water from a spigot when at base camp.
Sent from my SM-G930V using Tapatalk
