aernan
Regarding re-gearing the trucks. The factory ratio is 3.70 (in the differentials) and there is further reduction in the hubs (where there are gears). There are used 3.07 ratio differentials pulled from MRAPs. Finding these is becoming very hard. The original manufacturer Merritor is completely out and the gears. From what I am told there is a 7 month lead time to have them made and they AFAIK are not producing them yet.
I'm researching getting some custom 2.90 radio gears (ring and pinion) manufactured for our trucks. I have identified two companies that can do it and I have a wish list of folks who would want them. At this point I need to get more details on the existing gears so I can provide specs to those companies. A friend Oliver may be getting a set of high speed gears I located and I will take measurements from there. My truck still has the slow gears.
Regarding MPG. At max load the spec is 6.5 mpg. If you run the truck at lower RPM you can get 8 mpg. I have also been told that running higher air pressures in the tires can help. At some point the huge cross section and full time 4 wheel drive will be the biggest limiting factors.
I have concerns about fuel consumption so I am looking into ways to supplement my fuel with lower cost options.
