Lets see some full size pictures...
vargsmetal
Nearby Tri-States Rock, NY
Sent from my SM-G965U using Tapatalk
vargsmetal
I'm a bit jealous of your front approach angle there... ours is not nearly that good.
Yeah the front fascia of some of the GMT800s does hang down pretty low. This truck used to have a plastic splitter under the bumper but I took it off when I trimmed for the 285s. I usually hit the control arms or the diff skidplate before anything else.
  • Like
Reactions: rho
Regcabguy
Oil eater.
The Deaver mini-pack is expensive but 110% worth it. I put new OEM leafs and the Deaver mini pack on my '05 and it made an unbelievable difference. The long travel shackles will lower the truck, and not necessary unless you get longer leafs. My truck will flex to the bump stops hit and shocks max out with the stock size shackles.
My friend's Deaver mini-paks came with blocks. Carli's don't. How did yours come?
rho
Lost again
Ours isn't too low, but its still low enough that it was catching anytime that she had to cross a ditch or go over a tree or something. The front skid/splash guard thing all but destroyed as well. We're going to dig into the front bumper and pull the plastic bit off this weekend to see what can we do with it that won't look too terrible but increase the functionality. We're planning on mocking up some skids as well as the 2wd trucks don't have anything for em, really.
Ole Chipper
Finally got all the F-350 diesels together plus the Bronco. 93 red dually 7.3 auto with ATS turbo 125k miles. 94 ole F-350 firetruck 7.3l 4x4 auto 113k miles. 97 powerstroke 4x4 auto 184k and the Bronco 5.8l auto 160k plow rig.
lvcjt702
If only that Powerstroke was a short bed you'd have a perfect set!
Sent from my SM-G935P using Tapatalk
69machguy
Here's my 2017 F350 with an AT Habitat Truck Topper. The camper interior is a work in progress, and currently has a pressurized water system, 12V refrigerator, and compact kitchen with propane stove. I had a Carli 2.5" pintop suspension system installed to help manage payload and handling. I'm pleased overall and use it regularly. Still ahead is a front bumper w/winch, otherwise all good as is.
524947524948524950524951524952
Darwin
Awesome.
Lifting at all? If so, but those trailer fenders under the flatbed like the AEV jobber!
Not at this time, just some trimming for the 37" tires. The boxes are still higher off the ground than the lowest part of the undercarriage, but they do stick it out some. The flatbed is designed for camper.
Houie
