UJOR Build Thread
CaptainBuilt
For the beaches in Texas you may not even need 4x4 for the most part. Some soft spots here and there. I do not bother with the pressures, 45 psi on 305/65/18 and LSD rear and open front. I haven‘t been south of Matagorda, maybe farther south the sand is less compacted, but around Houston you will see a lot of 2wd Trafffic.
Mostly Bolivar is where I’ll be going. When you go over High Island bridge, and the road turns right, there’s a pull off where you can go miles down the beach and it’s empty.
I’m sure you know where I’m talking about.
Drizzt
Free Sarcasm Available
High top day!
Do you just bolt through the glass with a backing plate on the inside? Or do you need additional structural support built up inside as well? I'm assuming the top has wood bonded into the ceiling.
ujoint
Supporting Sponsor
We have them glass in an entire 1/2" sheet to the roof. And 1x6 around the sides. Roof rack gets thru bolted and glued with plates on the inside.
ujoint
Supporting Sponsor
Soft teardown today for this B190 that will be living in CO.
For those of you interested in my Volvo build, here it is as of today! The engine/trans is final install after some chopping and hammer time for some of the tight areas. Happy with all of the clearances now! Time to plumb & wire it all up.
jjohnny350
Dang Mane, That is going to be a rad wagon. Wow, really gets my wagon dreams flowing. Can't wait to see this thing. Thanks for the update, I love it.
Sigg
Looking sooo good! That thing is gonna be one fun wagon!
ujoint
Supporting Sponsor
Creampuff 1.0 is for sale
V45W_Proto2.5
