2019 F350 4x4 custom HPI flatbed/AT Atlas topper
mobydick 11
Mine is registered as just a "normal" 9999lb GWVR truck with my choice of OR plates, no truck or motorhome (both yellow plates here in OR). DMV didn't ask if I was building a "Camper Special." ;)
Well I did some more digging, and this may be helpful . What seems to happen according to the door sticker is ,even though you have lowered your GVWR the individual axle ratings remain . This would be helpful with a back end heavy camper . So in my case front is 5600 lb rear 6340 lb total 11,940. Even though lowered GVWR states 9,900 lbs , as long as you stay under that you can load either axle to gross . Numbers are from a 2019 F250 .And i am not suggesting how it would handle .
jonathon
Oregon is pretty easy. If it’s not a commercial vehicle as defined in ORS 801.210 it gets a registered as a normal plate.
With a camper permanently attached you will be a motor home. Depending on length it won’t be too much more to register and then you’ll be legal everywhere. You probably wont have any issues here but other states you might.
RAM5500 CAMPERTHING
OG Portal Member #183
It’s MORE in OR to be an RV?
In CA, it’s a LOT less, which is pretty mind blowing considering
mk216v
Der Chef der Fahrzeuge
Who determines if the camper is "permanently attached?"
jonathon
Yeah it’s by the foot as are campers and travel trailers.
Vehicles are very cheap to register here, $122 for two years. Additional fees for more fuel efficient cars. Still cheap.
That’s the magic question, it’s murky. Really it could go either way with a flatbed mounted camper.
Campers are plated separately from the carrying vehicle so that should be taken into consideration. It may be cheaper to register as a motor home then as a pickup and a camper separately depending on the length of the camper.
mk216v
Sub 21'ish.
mk216v
Update; still waiting to hear from Alum-line. BostomNagler ( :) ) suggested I have a 2nd look at Highway Products which is not too far away in Southern Oregon, since he had epic success with their products in Alaska/Dempster Hwy. So I reached back out to my contact there, was transparent that I've been talking to Alum-line. He said he wanted a shot at an estimate so I gave him the entire rundown of flatbed/boxes needs...now waiting to hear from him.
More to share once I hear from both of them.
mog
Kodiak Buckaroo
The DP pattern (code name 'Gladiator') is very cool as they stamp it in-house so it has a setback from the edges, not a cut-through the pattern like diamond plate. And being stamped into the aluminum it adds a lot of rigidity. I've seen it in person at the factory and it looks great IMO (I'm getting a quote for sideboards out of it)
Sample Photos
mk216v
Sample Photos
Gorgeous Mark! Would definitely add a lot of strength with the dimpling. I was headed towards smooth finish (as it'll be painted) vs diamond plate.
IdaSHO
IDACAMPER
Sample Photos
Damn good looking setup.
I might be a bit biased though... love me some custom flatbed Ford :oops:
xander69
