RAM5500 CAMPERTHING
OG Portal Member #183
Out of curiosity, why did you go with Suspension maxx instead of the Buckstop lift?
Buckstop makes top notch stuff, and i have ordered their wheels, bumper, steps and skid plate.
For the suspension though... I went with SuspensionMaxx for a few reasons:
-Adjust-ability, the adjustable upper arms will make a world of difference when aligning the vehicle during all the suspension trials and testing i'll be doing. I will be trying several different springs, shocks, etc.. Being able to adjust it for perfect alignment is huge. The Buckstop kit isnt adjustable.
-Completeness. SuspensionMaxx kit includes new sway bar links front and rear, not just spacers to move the existing ones like the Buckstop kit. The new ones are considerably beefier than stock.
-It's lower.. Just an inch, but its a 3" kit vs a 4" i want to keep the truck and COG as low as possible.
One important note about the Suspension Maxx kit versus the Buckstop is the lack of addressing the Track Bar. Buckstop provided a beefy relocation bracket to get proper side to side alignment. SuspensionMaxx does not.
After install and a test drive to settle the suspension, the axle is almost a full inch over to the drivers side. This obviously has to be addressed.
Again, i want full adjust-ability and there are only 2 options. Dodge-Offroad makes an adjustable beefcake track bar for the 4500/5500 or i can have a fabricator friend make the stock one adjustable by adding a threaded sleeve.
I havent had the best luck with Dodge-Offroad, but i ordered their track bar anyways, and will see how that goes. Time will tell... Trial and error.
Mostly in uncharted waters here.
