MIssion Overland Trailer Owners page
carbon60
Replaced the 3.2 GPM pump, head damaged by plastic shavings left in the tank, with a smaller 1.9 GPM unit and a pre-filter/strainer. First time using Watts Aqualoc/Sea Tech push-on fittings, which seem quite nice to work with.
(Mark sent me the pre-filter.)
mep1811
Gentleman Adventurer
Did Mark cover the new pump? I'll have to check if I have a filter on my system.
carbon60
I didn’t ask. I have a spare assembly I will swap into the previous pump to get it back to a working state, then I may carry it as a spare or sell it.
The hot water heater in this trailer maxes out at 1.5 GPM, and having a 3.5 GPM pump just wastes water.
A.
mep1811
I found some rivets that were not seated as well as large gaps between the aluminum "belly"pan and the frame. I sealed the gaps with silicone.
Tomorrow I'll will be running 12VDC up to the "headboard" part of the trailer . I don't think I can get AC power into the cabin without major work.
I'll have to use a small cig plug inverter for charging the laptop.
WU7X
Snow on the Roof
While you guys are having all this fun I’m stuck working in my garden. Really appreciate seeing how innovative you are.
gp01
