djschlo
TBD
Tundra: Last week, I winched the Tundra out a few feet and started stripping it. I followed the repair manual by Toyota, removed the transmission first then the 5VZ. I don’t believe it ever saw tools outside of the factory or dealership as everything was Toyota and properly torqued. I can’t get over all the room for activities in that engine bay.
5VZ Engine: I mounted the 5VZ to an engine stand and cleaned it up with some purple power and simple green. Before I test fit it, I want the engine to be ready for full time install. So maintenance and modifications will be done first. I have a timing belt kit, water pump, spark plugs, wires, ignitors, valve cover gaskets, etc. as preventive maintenance and tune up. I also have the replacement oil pan, and new oil dipstick drill guide. I might replace the crank pulley with a “performance” one.
Directions beyond the factory Toyota repair manual:
Valve cover- https://www.4runners.com/threads/2001-4runner-swapping-out-valve-cover-gaskets-pictures.3158/
Timing belt-https://adventuretaco.com/step-by-s...r-3-4l-v6-5vzfe-also-4runner-tundra-and-t100/
http://www.4x4wire.com/toyota/maintenance/timing_belt/
Oil pan replacement- https://www.offroadsolutions.com/tech-info/3-4l-5vz-fe-oil-pan-conversion/
Dipstick relocation- https://www.offroadsolutions.com/tech-info/3-4l-5vz-fe-dipstick-drill-guide/
Ideally, I will have the engine serviced this week and ready for mockup this weekend. Since the 5VZ only has 43k original miles, I don’t think it is worth doing much more beyond the timing belt, valve cover gaskets and basic tune up. But I am open to recommendations if I am missing anything.
Engine pictures.
Plans: I’d really like to be in a position to have the truck painted early August and the engine/transmission/transfer case swapped by the end of August. I should have all the parts I need to complete the swap by the end of August. I have not made decisions/commitments to other parts like seats, suspension, rims/wheels, or rear end yet. I am narrowing my considerations and continue to watch the local classifieds for other fun parts.
Engine pictures.
