Geo.Lander
Neither, but if your heart is set on that placement face them to the rear, if you drive off with them down they might survive.
Can you explain a little the Neither comment? They are freestanding.
At least if facing the rear you can use them for the garage locker
rear facing - that size of step facing out from the camper will become an obstacle that you are always having to walk around, especially if you have an awning on that side, plus you can use the side of the camper to steady yourself rather than needing a handrail on the steps
I have a strong dislike of "freestanding" stairs. They stick out way too far. They are inconvenient to deploy. They require level ground to rest on. They cannot be used when parked next to a sidewalk without blocking a lot of space, and more...Can you explain a little the Neither comment? They are freestanding.
An entry that has two steps inside the footprint of the habitat and one or two steps that deploy electrically or pneumatically is far better. The only issue is you cannot place the door over a wheel, but with a blank sheet for the design that should not be a problem.
We have/are spending a lot of time (a lot) in the design phase due to delays with our window, door and hatch supplier and now GRP panel supplier too, we have yet to start building the box (the subframe is starting this month). Every choice is a comprise of one feature over another and our rear facing U-Shaped seating is one of them as well as the large bathroom/drying room (1300*800) dictating the door placement. I suppose there is a lot of comprise, upside:downside and with every choice made one has to weight this in accordance with requirements and desires.
Take the delays as a positive. It gives you the time to plan and lock in a layout that will give you all you need with no compromise... A few things I see... First up, can you make your bathroom smaller? We all spend very little time in the bathroom... Secondly, as you are limited on length, you should consider setting up a perminant bed that drops down over the seating area, and lifts up out of the way when not in use. That'd give you a lot more usable space... Thirdly, Joe 917 makes valid points about cab access. Lastly, it's worth seriously considering getting the door away from above a wheel and adding a stair well. You can always have a flip down cover for the well if needed... Good luck!
As far as a cab pass thru, I can say I really don't miss or wish we had one
I think yours design is coming along nicely and should be pretty comfortable. You will get a heap of dust on the rear window, but it sure looks like a nice place to hang out.
So, for all the fun gear you mentioned. We have full back packing gear, MTB's, wetsuits, motorcycle helmets, 2 person inflatable kayak etc. One thing you might want to do is collect this stuff (if you have it already) and plan your rear under bed storage for it.
For your gray water, will it be outside? If so have you planned on a heating source for it (knowing what I know now I would have had in internal pipe built into our gray tank to allow our hydronic furnace to directly keep it from freezing)? Also, I know some people plumb the pee tanks to the gray water tank but I am not sure I would do that. For us a good portion of our time has been camping in remote spots with friends. Most of the time we all just leave our gray water drain valves open. One of the trucks we traveled with had a external under truck pee tank, it looked to be about 3 gallons and they could remove it as needed to drain it (though it might have had a direct drain valve also, but I never saw them use it like that).
Question! steps facing towards to cab or rear?
Thanks for the feedback Jon!
We actually measured our truck up for a crawl hatch over the bed, but then we would have to remove the bench seat in the rear of the cab which we really want to keep. And it also massively complicates things with our re-registration process for the truck here if we mess with anything in the drivers cab (including seats, etc).
Good point, I especially in winter up here. The Outbound windows have options for hardcovers, i might look into that
Yea, we have it all then some, we have GAS (Gear acquisition syndrome) pretty bad. We are planning on the rear toolboxes going full internal width, and hoping to keep skis, kite boards and larger items in the drivers side full length box, never enough storage, not sure what we will be doing with the kites etc yet..
Another valid point, we have spec'd a heavily insulated grey tank but not heated. My heating plans a still a little up in the air right now going back and forth between the hydronic furnace in the engine "room" and the Truma combi diesel. I expect we will go the hydronic furnace route and install additional webasto air blower for the bathroom. I have been mulling installing a low profile underfloor system (PEX pipes)... I need to spend more time on this subject for sure.
