Is the truck really in a derate state or is there just a loss of power?
When I first saw one in derate mode there was a very loud alarm going off in the cab and the top speed was limited to 5 mph. The vehicle power was reduced in stages over time.
If an alarm is sounding, try performing a manual DPF regeneration using the switch on the dash. The vehicle must be at operating temperature, A/C off and the parking brake set. When it fully completes the regen cycle and the  RPMs return to idle, shut the engine off and physically remove the key, then wait 5 minutes before restarting the truck. It’s like doing a Cntrl, Alt, Delete on a computer.
At the moment the truck isn't starting , when it did run I did a parked regen roughly every 10 days - maybe after 100 odd miles when it had 4 notches on the gauge .
For the last 6 months it went in to limp mode more & more till it did it every day .
I ended up taking it to a garage & they changed some parts like the egr , air flow , dpf pressure sensor & it still went in to limp mode .
Then a month or two later one day it cut out 7 times when driving , I've not used the truck since & can't work .
A local garage who's to busy said unplug the injectors one at a time when it's running ( it started a few times in my drive but after a while it would stall & not restart )
Unplugging one of the coils made no difference to how the engine sounded , I ordered another injector yesterday .
It's a crew cab , I didn't unplug the injector nearest the back as it was awkward to get to , I presumed there's no way 2 would be knackered at the same time .
I had a code on the dash saying high resistance on one of the injectors so thought that must be it ....
Today I checked the codes again & there's a new code for another injector with high resistance ( I'm sure that's what the codes mean )
At this point I'm hoping it is 2 bad injectors & not a problem with the ECU .
If anyone can tell me where all the grounds are that would be great incase I've missed one .
I've checked the main ground at the chassis beside the battery , the one on the gearbox , about 8 that are together on the front of the chassis & a small one that's beside some sort of small round relay that 2 positive wires go on to not far from the oil filter on the body .
Any help is much appreciated thanks .
