New 270 Awning available.
shoredreamer
@alia176 you can add the iKamper Exoshell to the 270 list.
only hard case 270 I know of in the USA.
Closed
96.5” long
Case is 7” out 6.4” tall
121 sq ft shade
66#
$1750 includes brackets25EE7AEB-F49B-4E06-8FDD-B005FE68E6C7.jpeg4D1F8B32-BBB0-4F4F-A45E-7CF7DE088A41.jpeg45A8BCC3-A125-46D5-A6AD-4224A55CB6A6.jpeg
alia176
Figured it's time to update this list as couple of new additions were added, thank you all for your contributions.
**************************************** 270deg awnings **********************************************
Freespirit Recreation 270
- No poles needed, $1100, closed dim=96", sq ft?, 37lbs :oops: (lightest awning), https://gofsr.com/products/freespirit-recreation-270-awning
iKamper Exoshell 270 - fresstaning but poles included, $1750, closed dim=103", 66lbs, 121sqft, ripstop nylon (may not UV reflective up top, my guess). @shoredreamer has pics on his 80 post #289
BF Campers (Canada) Freestanding up to 25 km/hr, $1,200 CAD$, sq ft? closed dim? https://www.bfcampers.com/product-page/270-degree-awning. (may not UV reflective up top, my guess)
ARC 270 by Roam Adventure company, 56lbs, need poles, 92sq ft, closed dim 90", $1400, ripstop sailcloth, (may not UV reflective up top, my guess) https://www.roamadventureco.com/products/270-awning?variant=43970998108392
Campking- Freestanding, Closed dimension 2.3m (91"), 24kg (53lbs), area? Coming from Aust. (maybe UV reflective up top, my guess) Sold by Rhino gear $2500 ,
Roofnest Litewing - 30 or 40 lbs depending on regular or XL model. Coverage is 70 or 100 sqft. The alum case is 7" wide x 8" tall x 100" long. https://roofnest.com/product/litewing-awning/ cost is either $1195 or $1295 (XL). Rafters are made of carbon fiber.
Darche Eclipse GEN2
48lbs https://overlandaddict.com/products/darche-eclipse-270-awning-gen-2, 87" length, 124 sqft,$1,299
Doghouse 270 - weight? https://www.doghousetents.com/products/free-standing-270-degree-awnings?variant=37027629858981, 92", sq ft?, $985 CAN
Wraptor 6k -
70lbs ( bracket weight is 5lbs x 3) https://overlandpros.com/product/wraptor-6k-270-degree-freestanding-vehicle-mounted-awning/, 88", sq ft?, $849
Wraptor 4K -
61lbs (includes bracket weight 5lbs x 2) https://overlandpros.com/product/wraptor-2500/, 86" length, ?? SQ FT, $800
Alucab Shadow -
24kg/51lbs https://www.alu-cab.com/product/270-shadow-awning/, 102" length, 100 sqft, $1,500
Rhino Rack Batwing -
47lbs (40# minus brackets) http://www.rhinorack.com/en-us/products/sport-leisure/shade/awnings/batwing-awning-left-_33100, 98" length,115sqft, $800
Rhino Rack Batwing compact -
40lbs https://www.rhinorack.com/en-us/pro...de/awnings/batwing-compact-awning-left-_33300, 79" length, 69sqft, $688
OVS Nomadic -
72lbs https://overlandvehiclesystems.com/...lack-cover-universal/#product-tab-information, 88", 129 sqft, $900
OVS LT (lighter model)
53lbs, https://overlandvehiclesystems.com/...7-dark-gray-cover-with-black-cover-universal/, 83" long, 80 sqft, $699
Peregrine 23Zero -
51lbs https://23zero.com/product/peregrine-270-us-drivers/ 88" length, ? sqft, $1,000
Kingsmen 270,
70# https://www.kinsmenhardware.com/products/awning, 91" length, 168 sqft, $2,150+4mos lead time
James Baroud 270,
weight? https://adventure-ready.com/store/james-baroud-falcon-270-awning/, ? length, ? sqft, $1500 (driver side only)
Bush company 270XT,
61lbs (53# minus brackets), https://www.southernxpeditions.com/bush-company, 90" length, 86 sqft, $1450, no poles are required or provided.
Bush Company 270 MAX,
73lbs (new to the market) https://cascadiatents.com/bush 270xt max awning left.html, 90" length, 130 sqft, $1750
Ostrich Wing
57lbs, https://www.ruggedbound.com/products/ostrich-wing-awning , 104" length, 120 sqft, $1480, no pole design,
Howling Moon 6 panel awning 2.5m-
38kg/83lbs with reflective material - https://www.howlingmoon.com.au/product/6-arm-270-degree-swing-awn, 98" length, ? sqft, $1795 AUSD
Howling Moon Swing awning 2.5m,
55lbs, https://www.howlingmoon.com.au/product/270-degree-awning, 98" length, ? sqft, $1390 AUSD,
Quick pitch weathershade 270,
60lb, https://tgmoverland.com/collections...k-pitch-weathershade-20-sec-awning-270-degree, 101" length, 161 sqft, $1380
EEziAwn Bat
46lbs, https://www.equipt1.com/products/bat-270-awning, 95" length, 80sqft, $1300
EEziAwn Manta
50lbs, https://www.equipt1.com/collections/270-degree-awnings/products/manta-270-awning, 100sqft, $1400
**************************************** 360deg awnings **********************************************
RLD DESIGN GhostAwn
360 Awning - 48lbs (weighed by Shoredreamer) https://www.rhinoadventuregear.com/products/rld-design-ghostawn-360-awning, 96" length, $1,400
Bundutec Bunduawn 360 DEG 44lbs, https://bundutecusa.com/bunduawn/ - no pole design 96" length - $1,515, 108" length - $1590, and 116" length
TexasIsHome
This thread is immensely helpful! We have a trailer coming from Hiker Trailer later this summer. They offer Rhino Rack but I’d read that some folks don’t like the Rhino Rack Batwing so I decided to shop for an awning separately. That trailer will have a galley in the back with a door that will swing open to the “driver’s side.” So I want a passenger side awning that will have decent coverage over the back. Seems like the Wraptor 4K or the OVS Nomad are my favorite options so far.
Did you ever decide on an awning? Our Hiker should be ready around Feb/Mar.
alia176
Closed
96.5” long
121 sq ft shade
66#
$1750 includes bracketsView attachment 751536View attachment 751537
Might I ask a favor please? Could you give add a third pic on your post of the awning closed up on your 80? It's immensely helpful to see the form factor on the sides of vehicles, at least for me anyway. Thank you sir.
shoredreamer
Just for you Ali! Haha! just Have the one i added.
TexasIsHome
Thanks to @alia176 for keeping the list updated, and @JMacs for sharing his excel sheet with me. I looked them over for a while, went back and forth between the OverlandPros, FSR, and OVS. Thanks to the BF/CM sales, I finally decided on the OVS 270 Nomadic passenger side mount. Arrived in a week, checked it out and looks/feels solid. I chose OVS for the ability to set up without poles, good coverage, and a 4 year warranty. I won't be able to mount it until Spring unfortunately.
TexasIsHome
Don't think I saw this one on the list. Looks like now they're offering a free awning wall as well.
Taruca
Extreme 270 @ $1299. 58LBS, 129 sq/ft, 98" long
Extreme dark 270+ version @ $1499. 62lbs, 145sq/ft, 91" long
alia176
Time to add the Taruca awnings!
Taruca Bushwakka Extreme Darkness 270
- three attached poles, $1500, closed dim=91" long, 145sq ft, 62lbs, https://tarucausa.com/taruca-extreme-270-lhs-awning/. Optional wall available.
Taruca Bushwakka Extreme 270 - one attached pole, $1300, closed dim=98" long, 129sq ft, 58lbs, https://tarucausa.com/taruca-extreme-darkness-270/. Optional wall available.
Freespirit Recreation 270 - No poles needed, $1100, closed dim=96", sq ft?, 37lbs :oops: (lightest awning), https://gofsr.com/products/freespirit-recreation-270-awning
Darche Eclipse GEN2
Doghouse 270 - 40lbs, https://www.doghousetents.com/products/free-standing-270-degree-awnings?variant=37027629858981, 92" length, area sq ft?, $985 CAN
Wraptor 6k -
Wraptor 4K -
Alucab Shadow -
OVS Nomadic -
Peregrine 23Zero -
Kingsmen 270,
James Baroud 270,
Bush company 270XT,
Ostrich Wing
EEziAwn Bat
EEziAwn Manta
RLD DESIGN GhostAwn
