Bushmaster5K
2020 JTR V6 auto, Alu-cab. 63k miles no issues.
The diesel is having some fuel pump issues as well as a few others. I have a gasser and that setup is the same as the wranglers. It is a well tested setup. The diesel also has a much lower towing capacity.
All diesels get 3.73, but the motor doesn't care until you go to 40" tires. Mine still cruises down the highway on 37's in 8th gear pulling a 19' travel trailer. The frame has some minor reinforcements and the steering knuckles are iron instead of aluminum. The ECU reduces power in the lower gears and between shifts to help preserve the drivetrain.3.6L V6
285 hp @ 6400 rpm
260 tq @ 440p rpm
3.0L V6 Diesel
260hp @ 3600 rpm
442 tq @ 1400 rpm
Does the diesel get any drivetrain upgrades from the factory with handle the added weight and power?
What is the factory gearing options for the Gladiator?
Same axles on both gas and diesel?
What about the tcase?
.The transmission is also built a bit stronger, all diesels get the "HD" wider axles and the springs are different to accommodate the extra engine weight.
-Dan
I have been driving Jeeps since the 60s, CJs,Tjs,Ljs,Jls and now aHaven't driven one, however the longer wheelbase results in a reduced breakover angle I understand. Also I’d prefer either a longer LWB vehicle (i.e, no tray, just the cabin) so that there’s more room inside, or a 2 seater cabin with a longer tray so that I could set up a bed in the tray.
Gladiator. It’s the best of the lot and by far the most versatile for my uses.Whoa.....What’s funny is he is right. History has shown all things equal a Chrysler is a turd compared to a Toyota when it comes to quality. That doesn’t mean you shouldn’t buy a gladiator though.
