DustBox - dust mitigation device - positive pressure system
Obsessed2findARuggedHybid
Thanks Nik! Full disclosure I was nervous at first cutting a hole in my trailer but folks should know that when done properly it's not a big deal and the hole is small.
Next trip I will get significant miles on some fine ID dust.
Just realized something. Maybe my wife will let me go to Burning Man this year. That would be the real testing!
Out on another trip. Mostly at 10,000 feet and fine dust. No sign of any dust. Very cool this morning 42 degrees. My percolator usually creates a good amount of condensation but not with the window cracked and DustBox fan blowing at 70%. Not one drop. So add a third use for this unit.
I know the new Xplores x145 and x195 have add some condensation issues. The DustBox would be a great mod for those trailers.
Suggestion: Saying professional installation puts the brakes on for some buyers I'm sure, I can see some ripoff RV dealer charging $300.00+ to put it on.
Devise a cover that fits over an existing RV window to provide the inlet for your box. Also, fabricate an adapter so you can mount the box inside the RV filtering outside air through a window. I doubt this would seal as well as what you plan on now, but no holes would need to be cut in walls or roof, big+!
Ozark any guess on how long it would take you with all your wisdom and skills to install this unit?
I think cutting a hole 5" by 5" is a much more secure and sensible mounting option then a side window. Placement on front high and center is best.
Pacific Northwest yetti
Expedition Medic
I think most shops these days have an rate of $100-200/Hr. ( For RV, Overland work) I am not sure what my brothers shop rate is for Zero Declination now, but probaly in there somewhere.
* Edit* Just as a reference. Personally I have no qualms at doing my own installs. I would like to think that a shop would not mess something up. But truth is, people are people.
Ozarker
I'm going to say, after due deliberation and after contemplating various scenarios presenting potential disasters, I have concluded that the average time to cut a 5 inch by 5 inch hole in the front wall of an RV built in North America utilizing generally accepted manufacturing processes comprised of building materials commonly used by manufactures with this task being accomplished by skilled or semi-skilled craftsmen, in good health, being of sound and sober mind, utilizing pilot holes to allow a cutting blade to be inserted and avoiding plunge cuts, approximately 4.2 minutes to cut the hole described.
It would likely take about as long for any ****************** to do.
The window was an option.
I'd like to see what's in this wonder box, I kinda think it's a filter in a metal box and there is no rocket science about it.
bshillam
Seeing what folks think and like to share their experience as far as retail built overland trail models.
We've developed a positive pressure system, called DustBox.
After building our own overland trailer, we've found that in desert or on extended bumpy gravel roads pesky dust/silt etc. get into various spaces, even with use of good/tight seals, Tern Overland's windows, etc.
I'm assuming I'm not the only one who loves to take those back roads, but hates the thought of "how much dust" I would be dealing with on the interior compartments, bedding or kitchen slide once I arrive at the destination.
Well, after almost a year of research, going through various setups, fan models, designs - my buddy engineer and I who does all the fab work & assembly - came up with DustBox.
DustBox is a positive pressure system (other names used in the industries - overpressure system / dust reduction system / dust mitigation system / dust control system, etc.),
It pressurized cabin space onto which its installed and maintains the pressure to keep dust out.
So far, largest test been done on a 23ft RV camper trailer. Has proven to do the job. Our trailer is a 5x10ft with 5ft walls.
System builds enough pressure to where I'm not able to shut the clam of the roof section while its running.
Potential use is varied, trailers, truck canopies, campers, etc., something to keep in mind that space has to be fairly sealed, as any large opening will not allow the system to pressurize the cab.
I'll be setting a booth at NWOR2024 this year in case anyone interested.
Currently looking for couple of trailer owners who can show that they truly use their trailers on some dusty trails to put our product to some testing aside from our own.
Upon a phone conversation, would be willing to send out a unit for your trials, and would love to get the feedback
PS.If anyone in Oregon (Salem locale) and is interested to see it in person - welcome to my home shop
Link to the product and pictures of our trailer & DustBox
I use my square drop off road, last trip was 700 miles off road. Super fine dust. Got everywhere. Had to lay a sheet over the bed before heading out everyday just to keep the bedding from being covered.
Nikson
Goal of this thread is to simply hear some opinions, expressions of personal experience in whatever the circumstances one might have gone through.
To each his own flavor, that we can all agree on I would hope!
For anyone curious about my product, I simply recommend reaching out to me directly via DM or through my website www.goadventureready.com
As a vendor at the NWOR2024 event, great feedback was received; sales made and folks are definitely starting to "learn" about availability of this product; but much education is still needed.
While many knew what it was from the first minutes of the conversations, many others (IMHO) left the booth not comprehending what it is or why they would care to have it although the "dust" issue is had by most (who truly take those unpaved trails)
DustBox isnt just a positive pressure system that helps user deal with dust intrusion, it also serves as a system that supplies clean filtered fresh air into the cabin area where its installed. Aside from helping keep the dust out, it helps with air movement and humidity control by bringing in fresh air in situations when one cant keep their windows open for various reasons.
Again, not every tool is needed by everyone, but many of us have various tools that we have just "because" - just saying!
p.s. thanks for keeping the thread on the topic and not high-jacking it sideways with other conversations
Recap of East Oregon trip where DustBox was put to some proper testing
Raspy
I built my own positive pressure system using a modified mid '80s Chevy van air filter and squirrel cage blower. The air filter has a water separator inside to collect and drain blowing rain and uses the stock air cleaner element. Water cannot get in, but filtered air can. A grill on the front of the snout keeps birds out. No insects can find their way in while camping because of the air cleaner element. It picks up its air at a clean air, positive pressure spot on the front of the trailer. The air cleaner came off of a 4 barrel carburetor model engine, so it matches a 4 1/4" hole through the wall. Inside, a deep stainless cooking pot from Walmart fits over the blower perfectly and trims it out nicely. A simple toggle switch turns it on or off.
Henrybrowne
